New Mod: Reverse Sensor & LED Display
Old Jan 12, 2006 | 04:18 PM
  #46
skeeter USA's Avatar
PS : I like to know if somebody can post the wright one so I can make sure I get what ya all are getting ,It looks to be real nice THANKS
Old Jan 12, 2006 | 04:26 PM
  #47
-TXF150-'s Avatar
Here is what you want, it has the display in feet.
SENSORS
Old Jan 12, 2006 | 08:07 PM
  #48
YOMAN's Avatar
I could have it next week !
I m curious how do you guys wire it to inside cab from the "brain" ?
HOw do you remove or put wire inside the frame (window) between the driver side and front windowshiled ??
Thanks!
YOMAN!
Old Jan 12, 2006 | 09:20 PM
  #49
runnerbl's Avatar
Thanks!
YOMAN!
YOMAN,
I ran mine under the frame making sure that I routed it over parts that kept it close to the frame. I took a screwdriver and pryed up the kickplate (go easy, it pops out..it is just clipped in), then I took off the plate that goes around the emergency brake release. Lift up the carpet and you will see a rubber circle seal. Pull it out and punch a small hole in it. Take the wire from the bottom of the truck and bring it through the hole, then stick the end of wire through the hole and pull slack through so wiring is tight. Pul rubber seal back in whole. Take the A arm interior off (piece that has the handle by windshield). The way you remove it is take off the 2 small oblong covers. Take a nutdriver and take out the screws. Piece will come right off. You should be able to run the wire from the floor up behind the seal and up to the window. I conected the display unit to the other wire and left the connection inside the A-arm piece. There was enough slack left over to tuck up under the headliner and make it over the the mirror. You will have to adjust here and there to get it the way you want it. Taking your time you can have it done in an hour. Hope this helps
Old Jan 12, 2006 | 09:41 PM
  #50
CTF150's Avatar
Don't know how I missed this thread before! I just ordered a unit for my Screw. Woman I'm dating will be happy when I get this since I backed into her garage door just the other week. No harm to her door but more important no harm to my truck!!!
Old Jan 12, 2006 | 09:42 PM
  #51
gobra's Avatar
Check out my gallery for my pics of my wiring. I think my writeup is somewhere in this thread or forum as well.
Old Jan 13, 2006 | 07:24 AM
  #52
YOMAN's Avatar
Got it!! thank you!
YOMAN!
Old Jan 13, 2006 | 08:17 AM
  #53
mrracqt's Avatar
sensors
I am still cunfussed about wiring the brain to the taillights. Can anyone explain where to attach it and how, will I short out the lights if I wire it backwards?
Old Jan 13, 2006 | 07:14 PM
  #54
runnerbl's Avatar
red whire goes to the red/black or it may be pink/black backup light. Black wire needs to be grounded. Thats it.
Old Jan 13, 2006 | 10:31 PM
  #55
RMS05's Avatar
Can you hook up the digital display to a factory sensor system?
Roger
Old Jan 14, 2006 | 07:52 PM
  #56
YOMAN's Avatar
I ordered it last weekend (shipped Monday from HK) and it arrived TODAY !!
the weather has been rain all day until mailman delivered the package to me and it stopped! so it let me play with my truck and installed LED reverse sensors for about 2.5 hours before it downpour rain again! WHEW!
I only got 2 instead of 4 cuz dont want to drill into metal bumper.not up for it.
I wired it inside side of the frame till driver side and wired it thru rubber and TA DA!
it works really good after test..its function good!
Where do you mount the brain?
Me, next to driver side frame(outside) bottom of bed with plastic wrapped cuz i was not sure if its waterproof or not, tied it up w/ zip.
I m curious- IS IT WATER PROOF ??
I m happy!
YOMAN!
Old Jan 14, 2006 | 08:15 PM
  #57
-TXF150-'s Avatar
I m happy!
YOMAN!
Just mount the brain inside the space where the tailight goes, that it the best place since water will not be able to get to it.
Old Jan 14, 2006 | 08:41 PM
  #58
runnerbl's Avatar
I wish someone would take a picture of how they mounted it inside the tail light assembly. i tried and couldn't get mine to fit in there. I have a bed rug so I just mounted mine on the side of the bed behind bedrug. Not where I wanted to put it but couldn't get it to set in light assembly. Take a pic so I can see how it was done.
Thanks,
Brian
Old Jan 16, 2006 | 08:30 AM
  #59
YOMAN's Avatar
hi please check this link that i posted last night and no one reply so i figured to post reply in here w/ link https://www.f150online.com/forums/sh...d.php?t=225071
thanks!
YOMAN!
Old Jan 19, 2006 | 11:03 AM
  #60
jcayer's Avatar
SENSORS
Thanks for that link, I ordered one from the seller last night!
Does anyone have a picture (or could someone take one) of where they mounted the sensors on a 99-03 bodystyle bumper? I have a 01, and want to see where everyone else is putting it on the bumper? I know it says a flat spot, but I would like a visual if possible? (I ordered the 4 sensor drill in kit)
Or should I start a new thread for visibility?
thanks in advance!!
