Reverse Sensor/LED Display-QQ and where to point at ?
Old Jan 15, 2006 | 08:36 PM
YOMAN's Avatar
Got em last saturday and installed it. it works really good and happy with it!
it only has 2 sensors on bumpers (where the plastic area is).
I m curious, do you guy set it direction point to distance ground, straight as horizon, oppsite side ( R- point passenger side L- point to driver side) or ??
It came with little O ring rubber with adjustment. do you guys use it ??
I used it and set it point toward a little oppsite side instead of straight but i am thinking about re-adjust it to only point straight horizon.
My conrcern is that our f150 rear bumper is a bit high compare to all cars (lower) and was wonder if sensor will "see" the low cars such as honda Civi etc (non-ricey cars) ???
How many feet does per sensor spread out wide and vertical ? any one know??
Thanks!
YOMAN!
Old Jan 16, 2006 | 08:32 AM
YOMAN's Avatar
no one ??
BTT
YOMAN!
Old Jan 16, 2006 | 08:35 AM
05supercrew's Avatar
I have the 2 sensers also but spread out and it will see a small car behind you. I didnt use the rubber rings.
