Just installed my new shifter handle (LT)
Old Jun 29, 2005 | 11:04 PM
  #61
purpony's Avatar
i replied to your email question-
but for everyone else... the chrome button is just a skin. It needs to be pryed off with a small straight blade screw driver. Takes some time but it will come off. there are 2 interal clips that hold the chrome piece on. I stuck a large screw driver inside the handle to hold the button out. Once the chrome skin is removed from the button you will see the pin that holds the button in place.
As far as removing the "leather" from the LT handle and installing it on your factory handle- good luck!!!! its not real leather and the min you try and remove it I have a feeling it will just fall apart!
Old Jun 29, 2005 | 11:27 PM
  #62
YellowFX4SCrew's Avatar
Thanx Purpony...
Greatly appreciated. I didn't get that email for some reason or just didn't notice it before I left for work.
Old Jun 29, 2005 | 11:45 PM
  #63
grayvader's Avatar
Looks like I'm on the bandwagon too. Can't wait to see how everyone's turns out. Just placed my order.
Old Jun 30, 2005 | 10:22 AM
  #64
I am at a stand still and will wait until someone posts some pics. I cannot figure out how to remove this button.
Old Jun 30, 2005 | 10:47 AM
  #65
crudeau's Avatar
I'd love to take some pics for ya, but I am at the 2 week mark. They tell me it isn't backordered. But 2weeks is the slowest boat ever.
Old Jun 30, 2005 | 11:30 AM
  #66
purpony's Avatar
if I have time when I get home I should be about to take a couple pics for you of how to remove ithe button... it was a pain in the butt the first time.
also.....when I installed the chrome top on the shifter i used silicone... but when the truck got hot inside it would keep falling off so i ended up using a little 5 min 2 part expony yo stick it on.
Old Jun 30, 2005 | 11:46 AM
  #67
Thanx Purpony, I was trying to figure out how I was going to keep the chrome top on the shifter. I snapped 2 of those little guides off.
Here are some pics up to the Chrome Button removal that will help visualize things:
Stock Shifter
Step #2
Step #3
More Pics to come...
Old Jun 30, 2005 | 11:49 AM
  #68
Here ya go...
Be careful of the spring...notice it's bent; I attempted to reinstall handle without properly seating the spring.
Scratches attempting to remove the "SKIN"
The other side...
Next to come...both shifters side by side comparison
Old Jun 30, 2005 | 11:51 AM
  #69
Both Shifters Side By Side...
Old Jun 30, 2005 | 11:53 AM
  #70
Last ones...for now...
And Later...THE REST OF THE STORY...
Credit due to Purpony for startin' this expedition...
Old Jun 30, 2005 | 02:53 PM
  #71
DAThomas9's Avatar
Wow. From the looks of the interior guts, I'm suprised this mod even works.
Thanks for the pictures - it will be a GREAT help when I tackle mine.
Old Jun 30, 2005 | 03:12 PM
  #72
purpony's Avatar
lol- yup... all the guts have to come out of the new one since they are preformed into the handle.
Then the original handles guts can be slid in place.
I used the chrome top off the LT handle but broke the 4 tabs off and then dremeled the center ring down a little..... and then used 5 min expony to hold it on. Also you need to do a little grinding on the factory guts to make them slide in but you should be what needs to be done. I ended up taking a little to much off so I used a couple little daps of 5 min there as well..... so far my LT handle has been working out great for the last several months and the feel is great!! and the looks are awesome!
Old Jun 30, 2005 | 03:16 PM
  #73
crudeau's Avatar
When you gut the LT handle, do you litteraly remove everything from inside it? So that it's basically just a shell with leather around it. Or is there anything that stays inside.
Old Jul 1, 2005 | 08:36 PM
  #74
Just wanted to see what the status was on the Chrome Button Removal process...
Thanx...
Old Jul 2, 2005 | 07:26 AM
  #75
AhsGrad1973's Avatar
I would advise when you grind the plastic out of the new handle, do it outside or in your garage. I stunk up the house when I did mine yesterday. Like Purpony stated, it takes a little patience and a steady hand to grind it out. After you get most of it out, do a little at a time, checking the fit as you go. Easier to grind more, then to do too much. I had to read Purpony's instructions a couple of times about the plastic chrome button being a skin, and where the pin was located, lol. I too broke off the little plastic tangs on the top chrome cover, I used some RTV. I thought about using expoxy, but didn't want to use something where I couldn't remove if necessary later on.
