my F-150 needs a cam replace at 1352 miles
My new f-150 is in for service due to a loud tick. I was hauling my snowmobile trailer up a hill when my service engine light started flashing, truck started virbating and lost power..... Now it has a very loud tick on the drivers side-
I just talked to the service manager and they just got off the tech line with ford and this is what he basically said-
"my truck needs a new Cam and all the followers replaced on the drivers said. According to ford this is a very complicated engine and due to break in and tight tolerances on the engine it could have a lubricating problem sometimes on break with the cams-"
WTF.... anybody ever hear this problem before????? My truck only has 1352 miles on it! Its an 04 Lariat.....
should I demand a free extended warrenty?? Im worried if I have problems at 1300 miles... what type of problems will I have at 100,000 miles???? And I wanted to pipe, chip, and lift this truck....
Originally posted by RockyJSquirrel
A problem like that is obviously a manufacturing defect, NOT a wear problem. So what does this have to do with anything at 100K miles or more? Not a frikkin' thing. If you wish to panic and complain, sell the damn truck and buy a Chebbie.
Purpony,
Although rudely put, RockyJscreamal is probably right. It sounds like a manufacturing defect. What you might do is ask your dealer about a WHOLE new engine. In fact, I would insist on it and not back down. The possibility of shavings from your incident in the block now can't be ignored, and may cause other problems down the road. The scenario isn't probable, but it is possible. A new motor altogether would not cost the dealer all that much more than repairing your current one. I would really pursue it.
Good luck!
Re: my F-150 needs a cam replace at 1352 miles
-2004 Aspen Green Lariat Screw- tinted windows, CW billet grille, Retrax bed cover, Magnaflow exhaust, Diablo sport programmer, 2.5 autosprings spacers, Eagle 178 wheels, BFG A/T 285x65x18
![Roll Eyes (Sarcastic)](https://www.f150online.com/forums/images/smilies/rolleyes.gif)
There were a batch of heads that were manufactured with the rockers on backwards or something to that affect that I remember reading about here some time ago.
You don't say what your build date is, but this sounds similar to the problem.
Search around and you will find the threads.
I wouldn't get too worried about it.
![Wink](https://www.f150online.com/forums/images/smilies/wink.gif)
My two cents...
Just to let you know, here's what I would expect when you take your truck in:
1) They'll go ahead and replace the cam.
2) They'll end up putting some new heads on too. At least on mine they did.
3) They'll check something in the engine called a lifter (?). Don't know if that's for oil or lubricant or what...(btw- can someone tell me what the heck that is???)
4) If you haven't gotten a computer reflash, they'll look into that.
My truck had about 15k on it before it started doing some funky stuff. Driving down the interstate one day at a modest 75 and engine kinda kicked a bit. Engine light came on, then turned off. Truck went back to normal, but it felt like it had lost just a bit of power and kick. I was also noticing the vibration and nibble in the steering was getting worse (I coulda lived with it the way it was, but it got bad after that engine kick), so I took it in. This is what they told me, this is what they did, and now my Screw runs like a beauty again.
A "lifter" is a valve lifter.
It looks like a shiny metal cylinder that is about the size of a 2/3 roll of quarters.
Its sits on top of each camshaft lobe and on top of it is a pushrod, which ultimately rests under the rocker arm, which rocks back and forth as the pushrod lifts up and down as the cam lobe gets bigger and smaller (think of a circle with one end squashed - thats a cam lobe).
As the rocker rocks back and forth it opens and closes a valve (intake or exhaust - take your pick), your engine breathes, combustion occurs an viola, you can video a burnout with your new F150 and post here for all to enjoy.
Tomorrows topic will be heated mirrors.
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
![lol](https://www.f150online.com/forums/images/smilies/lol.gif)
Hmmm...I didn't think OHC engines had pushrods...
Re: Re: my F-150 needs a cam replace at 1352 miles
Originally posted by asinatra
Full of BS. Your didnt break your truck in right, and you were probably haulling *** up the hill with a trailer. And your sig says...
Now it says your have a a programmer and exhaust? What else could you mean by "pipe" & "chip" ? Now untill i hear what the excuse is, i am waiving the bs flag.
I have been breaking my truck in right since i picked it up on Jan 14. and Waiting 700+ miles before hooking my sled trailer up to it.... which is a max of 2100 lbs with 2 sleds in it. I was pulling a hill in VT at 60-65mph with over drive locked out and the service engine light just started flashing and the truck lost power and starting vibrating very bad........ I let off the gas and drove about 20 mph to get to the top of the hill.... I was not beating on it what so ever!
However its a truck and its designed to tow 7-8000 lbs.... I was not even working it.
I just got back from the dealer and my truck has the valve cover pulled. They are replacing the cam and all the followers(rockers).... according to the tech at ford they have seen a few problems with the cams not being prelubed from the factory correctly..... of course with my luck it looks like my truck was one of them. Off the top of my head i dont know the exactly build date. Im just pissed this happened in the first place. I bought a new truck so I didnt have to worry about my old truck breaking down on me up north... now my new $40K lariat is worse then my 200K mileage old truck is..... and will be in the back of my mind always.... My modded d windowinted windows, chrome front blinker bulbs, and a Carriage Works Grille and bumper insert!!! My Retrax cover is still sitting in the box in the garage along with my wheels. Everything else were future plans....
