Stock Speaker
Old Dec 25, 2004 | 09:08 PM
Scubaman's Avatar
Stock Speaker
I just recently upgraded to a pioneer head unit. I am about to install the pioneer tuner for xm and the antenna. My stereo installation guys seem very fair and honest and do great work but I was wondering if anybody had ideas were to mount the antenna and tuner. It is not the commander that gets installed in the ashtray. Also, my stereo guys said that the stock spaeakers were adequate. Should I replace the speakers I have a bazooka tube in the back and the baee sounds ok but the speakers to me aare a little week.
Old Dec 25, 2004 | 09:51 PM
KC8FLB's Avatar
If I were installing it I would install the xm "brain" box securely in the cavity behind the radio (you could fit a case of beer back there) I would also install the xm magnetic antenna up on the roof just in front of the third brake light, and I would run (and sillcone seal) the antenna wire inside through the third brake light opening.
The antenna needs to "see" the satellite and the roof is the best place for that to happen.
Enjoy your XM, I enjoy mine everyday
Merry Christmas!
Old Dec 26, 2004 | 03:07 AM
Scubaman's Avatar
stock speakers
What do you think about the stock speakers. I was thinking of replacing them with infinity. Will it make a big difference?
Old Dec 26, 2004 | 07:50 AM
KC8FLB's Avatar
Aftermarket speakers will generally be clearer and hopefully will be more efficient (A little louder) You need to listen to a bunch in the showroom yourself, and find the one that your ears like best.
If after replacing the speakers, the bass still drowns out the interior speakers, then you can always add an amp or turn down the bass a bit. The nice thing about car audio is that you can do it in stages.
Old Dec 26, 2004 | 02:29 PM
Scubaman's Avatar
stock speaker removal
Is it hard to remove the cover or the speaker? it looks tough and there are no screws anywere.
Old Dec 26, 2004 | 02:50 PM
powerage's Avatar
You have to take the door panels off.
Old Dec 26, 2004 | 08:24 PM
FazMan's Avatar
For the front speakers, you just have to pop the grill off that is around the speaker. There is a small notch on the side of them so that you can get a pry tool in there if you need to. I was able to just pull towards me and they came right off. For rear speaker access, you have to remove the entire panel because the grills are part of the panel. Here are the instructions on how to do that. It is pretty much the same for the s-crew and the s-cab.
Old Dec 26, 2004 | 08:53 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Thumbs up
I replaced my stock speakers with 6.5 Infinity components a couple of years ago. Best $200 I ever spent(I did the labor),,,,98
Old Dec 29, 2004 | 02:04 PM
speedwolf's Avatar
I replaced my stock speakers with 6x8 Infinity speakers. Just take it easy when removing the speaker grill in the front doors. The tabs have a tendancy to break easily. I ended up having to order a new grill because I broke so many of the tabs. Oh well, live and learn and pass it along.
Old Dec 29, 2004 | 03:39 PM
04fx4Scab's Avatar
Re: Stock Speaker
Originally posted by Scubaman
...I was wondering if anybody had ideas were to mount the antenna and tuner.
i just installed a new kenwood radio with a sirius tuner and i had the same problem; where to mount the tuner. I mounted the tuner to the underside of the rear seat (drivers side). There is a metal bar that runs under the seat (i have a scab) and is covered with the seat material. I had to drill a few holes but it turned out really good and it is up off the floor and out of the way. I mounted the antenna on the roof just in front of the 3rd brake light and ran the wire under the seal and into the cab and then down to tuner under the seat. I ran the cable from the tuner to the radio under the carpet on the drivers side, just under the step molding. It turned out really good and I am happy with it. I will post pics tonight when I get home from work.
Old Dec 29, 2004 | 07:05 PM
04fx4Scab's Avatar
here are the pics of the my sirius satrad install with kenwood kdc-x579 radio. my new rockford fosgate speakers will be here tomorrow. there's more pics in my gallery. hope this helps.
fastened with two screws to the metal plate under the seat.
i ran the antenna wire around the side of the lens and went in thru the bottom under the gasket.
Old Dec 30, 2004 | 09:18 PM
Scubaman's Avatar
stock speakers
Thanks for the pics the install looks great. I spoke to the shop were I am getting the xm installed and I asked them about replacing the stock speakers and he recomended not too. I thought hat was weird. He said the stock ones are nice.
Doest the antenna leak or cause any problems at the car wash?
If i buy the infinity speakers do I need to install the crossover that comes with it or can I just replace the tweeter and the main part?
Old Dec 30, 2004 | 09:33 PM
DrkShadow's Avatar
The folks that did my install said the used to wire thru the 3rd break light. They said they stopped cause they got compaints of leaks in the light housing.
This is where mine is. A bit closer run maybe too. Front drivers side.
Old Dec 31, 2004 | 12:54 AM
speedwolf's Avatar
If you get the Infinity speakers with the separate tweeter, you'll have to mount the cross-over somewhere. If you don't want to do that, you can get a set of the Infinity Reference 6800cf which have an adjustable tweeter on the main speaker (can turn it 350 degrees to point to the right spot). I put those in the rear doors of my truck. The front speakers are the Reference 6802cs.
Old Dec 31, 2004 | 07:05 AM
Peacemaker's Avatar
I have Infinity 6x8's in my 01 along with an amplified 8" bazooka bass tube and kenwood cd player. It sounds pretty good for a $600 setup.
