where was the answer/ Rancho 4"
Old Nov 17, 2004 | 02:47 PM
cavenaugh's Avatar
I didn't see that the ? was answered.
Does the frame need to be cut in order to install the Rancho 4" lift
Old Nov 17, 2004 | 02:51 PM
dzervit's Avatar
Cut the frame?! That's crazy talk. What lifts require you to cut the frame?!
Old Nov 17, 2004 | 02:57 PM
cavenaugh's Avatar
UMMMMMMM?
It would be my understanding that the Procomp 6" requires cutting the left side crossmember bracket.
I will research.
Old Nov 17, 2004 | 03:05 PM
dzervit's Avatar
Brackets I can see, frame I cannot. I guess I took you a little to literally...
I still think the Rancho is a bolt-on. For the best answer, call 1-734-384-7804 or visit http://www.gorancho.com/techsupport.stm
Old Nov 17, 2004 | 03:10 PM
Truck of Doom's Avatar
I don't think the ProComp requires any cutting. I know the Fabtech does.
Old Nov 17, 2004 | 03:13 PM
cavenaugh's Avatar
Thanks for the input. My main concern is that if I need to, return the suspension to its original for whatever reason. I.E. Warranty issues.
Thanks again
Old Nov 17, 2004 | 03:54 PM
Bullitt4711's Avatar
That scared me for a second!!! lol
Old Nov 17, 2004 | 03:56 PM
cavenaugh's Avatar
Lightbulb Is that your final answer?
OK,
Yes the fabtech requires cutting and drilling,
Yes the Procomp requires cutting and drilling,
AND
Thanks to Dzervits input and suggestion, I called Rancho and
YES the Rancho 4" requires cutting and drilling the same left side rear crossmember bracket as the others to install and, To return the suspension to the OEM specs you must retain this bracket and reweld it.
So there it is. Time for lunch
