Went to the dealer...
Picked the car up, didn't hear the dash noise at all....
Service paper said loose wire loom.
Then this morning heading to work it returns. Its gotta be the dash rubbing against the windshield. Passenger side corner, if anyone has this same problem please let me know. Its a squeaky kind of sound.
Originally posted by Net Wurker
If the tail-gate straps are not equally supporting the weight of the tail-gate while it is in an "down but unutillized state", this can lead to the accumulation of water in the third brake light housing. If this condition goes untreated, the water sloshing around in it may cause a steering wheel nibble, which may or may not evolve into a full blown vibration. This vibration will shake the solder joints of the main board in the PCM, causing them to vibrate loose, which will result in intermittant stalling and throttle lag.
Those tail gate straps are important!
Originally posted by sweetsc
go to the outside of the truck and tap on the wiper cowl and see if it is loose and making the noise you are hearing. I have the same problem.
Chris
Chris
will have to try that...
Re: Went to the dealer...
Originally posted by im_poor
Problems:
Automate Alarm didn't activate
Dash Noise
Tailgate Strap
Buffing/Swirl marks
Throttle Lag
Throttle Lag, I asked for a reflash he said it won't help and to get a Superchips tuner.
Problems:
Dash Noise
Tailgate Strap
Buffing/Swirl marks
Throttle Lag
