will 17x9 -8 offset wheels fit
Subscribe
Oct 30, 2004 | 12:52 PM
im going to add a 3" Skyjacker lift. so i want to know whats the best size tire to run with this wheel. thanks
Reply 0
Oct 30, 2004 | 02:49 PM
anyone?
Reply 0
Oct 31, 2004 | 12:55 AM
no one is running this wheel?
Reply 0
Oct 31, 2004 | 01:27 AM
Which wheel is this? Is that a -(negative) offset of 8" or 8mm?
Try THIS.
Reply 0
Oct 31, 2004 | 08:54 AM
its the Eagle Alloy 186 or 187 in 17x9. on www.aewheel.com it says that weel in 17x9 has a -8 offset. im having trouble seeing if this will fit.
Reply 0
Oct 31, 2004 | 10:08 AM
With just over 4" of backspacing, the wheel will clear, but you may have some serious rubbing issues depending on the tire size you choose.
Generally, you'll be better served with a wheel closer to the lift manufacturers recommendation.
Reply 0
Oct 31, 2004 | 10:20 AM
SVTErick,
Here's a pic of my truck with 2" lift. 17x9 with +25 offset, 295/70-17 (33" tall) The wheel you describe will stick out 1.75" more than the one in the pic which is gonna put it closer to rubbing in the area shown. Put a bigger tire on and it's gonna be even closer.
Reply 0
Oct 31, 2004 | 10:23 AM
i see what your talking about now. well then who makes some other 17" wheels in the offset i need then? thing is i could always go with these and a 33" tire and be ok i think.
Reply 0
Oct 31, 2004 | 10:31 AM
red wing nut i love your wheels what brand are they? would those wheels allow me to run the 305/70's or the 285/70's?
Reply 0
Oct 31, 2004 | 10:32 AM
Quote:
Originally posted by RED WING NUT
SVTErick,
based on your calculations i could run the 186 wheel which will be 1.75" further out than your wheel but if i get a 285/70/17 tire itll be a bit smaller than the tire your running now. question is if that balances itself out.
Reply 0
Oct 31, 2004 | 12:14 PM
how about i hold back on the wheels and jjst put the 305's on the stock wheels? i may buy your same wheel RED WING NUT or one similar to that later on but for right now i guess ill buy the 305's or the 285's. so basically my question now is will the 305/70 tires fit on the stock tire with a 3" lift and will they fit fine on a 17" wheel with +25 offset?
Reply 0
Oct 31, 2004 | 12:48 PM
Yes you would be OK with the stock wheels or wheels like mine and the 305/70's.
Reply 0
Oct 31, 2004 | 02:08 PM
GREAT! thanks dude
Reply 0
Subscribe
