any 2wd 2004 F150 lift kits available?
Old 10-24-2004, 05:24 PM
SVTErick's Avatar
ive been looking around but have only been able to find 4wd lift kits
Old 10-24-2004, 06:18 PM
SVTErick's Avatar
im looking into lifting my truck. any recommendations? i KNOW NOTHING about lifts or lifting. if anyone could give me a quick run down of the parts needed and where i could find them. im thinking a 3" lift. nothing to big. also whats a good tire and tire size to go with? i was thinking 285/70/17. thanks!
Old 10-24-2004, 07:11 PM
SVTErick's Avatar
on this website rockymountainsuspension i found a skyjacker 3" kit for $550 but what exactly does this bring? i also found on Ebay some Eagle Allot 187 wheels for $350.
Old 10-24-2004, 07:53 PM
hoff's Avatar
Im almost positive that the 4x4 and 2x4 kits for the 04 are the same.
Old 10-24-2004, 08:12 PM
SVTErick's Avatar
well heres another idea on the 3" lift. could i also use a daystar 2.5" kit on the front and have a 5.5" lift up front but then i would be left with a 3" out back how to i level that out?
Old 10-24-2004, 10:48 PM
hoff's Avatar
svterick,check out the rancho 4"lift.It will raise the front about what your talkin with the combo setup but in addition it will have the rear lift.Or do like u said and add a-leaf with blocks in the rear.
Old 10-24-2004, 10:57 PM
wandell's Avatar
I also believe that the 4x2 and 4x4 kits will be interchangable. Check with the manufacturer to make sure though. All of the spacer or leveling kits (Daystar, Auto Spring, RevTek, Skyjacker) are interchangable between 4x2 and 4x4's. I know that Fabtech and Pro Comp both advertise 6 inch lift kits for 4x2's. You also have the option of a 3 inch Performance Accessories body lift. If money is an issue, you could go with a body lift and one of the leveling kits. As far as raising the rear, you can add a lift block or add-a-leaf to the rear to get the height you desire.
Old 10-25-2004, 07:34 AM
SVTErick's Avatar
what would be the difference between a 3" body lift and the 3" Skyjacker lift? cost is a factor here. i have around $1600 to spend on lift, wheels, and tires. ive found some good deals on the wheels on Ebay. im still looking for the tires im thinking some 285/70/17 i should be able to clear right?
Old 10-25-2004, 08:06 AM
wandell's Avatar
The Skyjacker is a suspension lift. Their 3 inch kit consists of a replacement coilover shock and an add-a-leaf for the rear (I think). The body lift lifts the body only. I'm not sure of the price for an 04 body lift (mine was about $115), but it will be a lot less expensive than the 3 inch Skyjacker lift.
Old 10-25-2004, 08:24 AM
SVTErick's Avatar
what are the pro's and con's? how about a 3" body lift and the 3" Skyjacker lift. would that work out? i would need some new shocks also right? anything else?
Old 10-25-2004, 08:27 AM
SVTErick's Avatar
found a 3" lift but its expensive! may i should go with this till i can get the skyjacker and new shocks?
http://performancelifts.com/cgi-bin/cart/PER70063.html
Old 10-25-2004, 10:28 AM
SVTErick's Avatar
performance accessories has a 3" body lift that i could buy instead of the skyjacker lift and with the extra money upgrade to some good shocks? what do you all think although it says the body lift is only for the 5.4? why would that be?
Old 10-25-2004, 04:21 PM
wandell's Avatar
$269 is cheap compared to a full suspension lift (althought that is high for a body lift). I don't know why it wouldn't work with a 4.6. If money is an issue, go with one of the coil spacers and the body lift. THis will make the truck level and give your about 5 1/2 inches of lift up front.
Old 10-25-2004, 06:04 PM
Truck of Doom's Avatar
269 for a 3" body lift or 550 for a Skyjacker suspension lift? That's a no brainer. Get the Skyjacker.
Old 10-25-2004, 07:50 PM
SVTErick's Avatar
yea im going with the Skyjacker kit. im gonna do it right the first time around.
Quick Reply: any 2wd 2004 F150 lift kits available?
