Supercharged/Turbocharged?
Old Sep 30, 2004 | 08:39 AM
  #31
FATHERFORD's Avatar
Would someone show or tell me what type of turbo comes on the basic kit.
To "upgrade" a turbo to get get 15psi is bull****. Nearly all turbo's can alteast go 20psi. Alot go to 30psi+ before they are out of there effiency range.
Old Sep 30, 2004 | 10:13 AM
  #32
jojones's Avatar
Probably because of not enough exhaust energy. It Probably upgrades to a Ball Bearing unit. Heck a stock Garret 38 will produce 23lbs all day long with no problems. Move to a Gt ball bearing 38 and it's good up till 40lbs. So that makes me think that because of the turbo being so far away their is not a lot of exhaust energy left. I'm no engineer that's just what it sounds like to me. I just used the 38 for example because that's the only turbo I really have dealt with.
Old Sep 30, 2004 | 02:34 PM
  #33
Bullitt4711's Avatar
Most higher boost turboes have a larger caseing. They also usually take longer to spool up to full boost. Thus with a smaller tubo that has a lower boost level, you can achieve more efficient boost sooner.
Old Sep 30, 2004 | 08:33 PM
  #34
FATHERFORD's Avatar
Yall dont understand turbos and there operation. I have and played with MANY turbo cars. There is not a turbo i have messed with that cant go to 20lbs of boost, t3's to t88's..
Old Sep 30, 2004 | 08:35 PM
  #35
Read again what I said, I never said they couldnt handle it.
