Please define " Hood Shake"
Although I check this forum regularly I must have missed previous posts about "Hood Shake"
I have had 2 2004 F 150's and neither of them had any problems....except, when running at freeway speeds I notice that the edge of the hood nearest the windshield is vibrating.
When I first saw it for a moment I was thinking the hood hadn't been latched down properly...then I thought...."You eejit !...
It's a front opening hood !"
For a moment I had thought perhaps the rear end hadn't latched down correctly.
I do have a bug shield (Non Ford) but have not noticed vibration at the front.
Is this what you have been talking about or is this something else !?
I had an aftermarket bug shield for awhile, which caused the hood closest to the windshield to vibrate up and down like there was no tomorrow. It was a pretty high profile shield, and once I removed it the problem went away. I returned it for a refund, and was told that the manufacturer was aware of the problem. The low profile shields apparently don't cause the problem. I have yet to get a new one, but may in the near future. I figure I've waited long enough now that the bugs may be worked out...
In 12,000 miles, I have only seen it once. We had some snow in early spring, and about 4 or 5 inches stuck. I was driving down the road with 3 or 4 inches of snow on the hood, it was 'lifting' at the lower left of the windshield.
I installed the Ford OEM bugshield and still have no problems.
I have said it before and will say it again, I think the snow messed with the aerodynamics of the hood and caused it to react that way. I still think that some of these bugshields are not being installed properly. When I put mine in, there was some give in it before I tightened it. The gap between the hood and the bugshield can be increased or decreased and still be tightened down to the truck. I feel that if the gap is too big, it has the same result as it screws with the aerodynamics. Just a theory. Maybe someone with the hood lift and a bugshield would be willing to loosen the bolts, make sure the shield is slid all the way towards the truck and retighten. I think it'll fix it. Someone let us know.
![beers](https://www.f150online.com/forums/images/smilies/beers.gif)
I had a horribe hood shake on my FX4 and after reading the previous posts i took off my bug shield (a painted one ford put on as a option at ford of ocala) The hood shake all went away and i like the look without the bug shield, but i think the bug shields are a bad design not only do to air disturbences, but they get wedged down between the edge of your hood and your grille. On my truck this caused a even gap all the way around about 1/8" where it should be flsuh which i was not happy about. on top of that there was a chip, a large one, right under the bug shield. Looks like from some moron trying to inititally install the thing. O boy i was not happy. Anyways getting true duels tommorrow
![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
I see it too and I only have 1200 miles on it. I recently put a low profile bug shield on the from (OEM from ford) and noticed a decrease in the "hood shake"
I attribute it to being by design - a hood that floats per say designed to decrease body stiffness since the frame is "stiffest ever"
It can also be attributed to the fact that the hood laches down near the bumper giving it less rigidity?
Who knows - its a Ford thing.. Just like the dreaded "Bed Shake". OooooooooooO
![EEK!](https://www.f150online.com/forums/images/smilies/eek.gif)
Hey Guys, I have a Lund shield hanging in the garage the last 3 months, made the hood shake and a wind noise on the mirrors. Lund told me I could take it back to the dealer for a refund. Just havent driven that 40 miles back to do so. I also had some off brand "in the tracks" vent shades that caused air noise.. the front two are on the self with the shield .
see my ride at: https://www.f150online.com/galleries....cfm?gnum=3309
![fyi](https://www.f150online.com/forums/images/smilies/fyi.gif)
I'll bringit back up. I have about 11,000 miles on my 04 roughly a year. I just noticed the other day my hood shake, I have no bug sheild. Anyone found out the real reason behind this yet, the dealer I bought from sucks and I refuse to go back there unless there is a mandatory recall that says the truck will blow up while someone is in it. Any ideas?
I believe Quintin posted a summary of the TSB on hood shake if you wish to search it out. The fix was to test the rear hood weather seal for proper fit by placing a piece of paper in the rear opening, closing the hood on it, and pulling it out to see how tight the seal is. If it did not seal properly, the seal could be reinforced by threading some rubber tubing into the hollow center portion of the weather seal.
