Rear window
Old 07-27-2003, 10:55 PM
JOB1124's Avatar
Question Rear window
Orderd a FX4 SuperCrew in may. I got the sliding rear window but after looking at the options list on kbb I realized that the solid window is the only one of the three with a defroster. Since dealer told me my truck will not be built until late august I still have time to change my order. I like the defroster option but I also like the slider. Would I be better off getting the slider & put a after market defroster in or go with the solid. Any opinions would be appreciated.
Old 07-28-2003, 07:38 AM
APT's Avatar
APT
APT is offline
With a pickup's vertical rear window, there is rarely a problem with dew and frost on it. Fog inside, I suppose, but the cab is relatively small and the A/C defrost works quickly for all windows inside. I had a slider on my 99 and again on my 03. Never has there been a time I wished for a defroster for my window. I use that slider a lot, though.
Old 07-28-2003, 07:45 AM
purty_2004's Avatar
APT is right!
Old 07-28-2003, 08:17 AM
01 XLT Sport's Avatar
I live in New Hampshire and last winter was a real PAIN, lots of snow, lots of ice and lots of ice on the windows.
However the rear window was never really that bad. I have a slider. In the worst cases the little bit of frost on it would melt within 5 minutes or so of having the heat on inside the truck.
If it were my choice between slider or defroster I would go with the slider. If you find that you "really" need a defroster then go with an aftermarket, but I don't think you will really need one.
Old 07-28-2003, 08:24 AM
serotta's Avatar
We get a bit of snow and ice here in NC, mostly just frost. I also have two firebreathing dragons, most of the rest of you call them children, that constantly try to fog the rear window. I have never wished for a rear window defrost. Three minutes at operating temperature clears the rear window. The slider is an option that is used daily.
Old 07-28-2003, 12:12 PM
Rockpick's Avatar
Moderator &
I'd definately have to vote for the slider. As APT mentioned, condensation and moisture typically isn't a huge issue on the rear glass.... I can imagine scenarios where I'd want one but they are far outweighed by the slider and the nice air flow coming through the cab when it's a pretty day.
Just my $0.02
RP
Old 07-28-2003, 09:43 PM
JOB1124's Avatar
Thumbs up Rear Window
Thanks guys for your opinions. Looks like I will stick with the slider.
Old 07-29-2003, 12:32 AM
pa_wolf62's Avatar
Re: Rear Window
Good choice the solid rear glass sucks. I wish I had the slider almost everyday.
Quick Reply: Rear window
