need help shaking in front in but almost all new parts.
Old 02-13-2018, 08:23 AM
F150hillbilly's Avatar
ok I have a 01 F150 Lariat had it a year now but it was neglected so I've been rebuilding.
so far in a year I've put on both new lower ball joints (moog problem solvers), both new upper control arms (again moog), all four shocks (motorcraft), rear U joint (moog), 6months ago set of 4 khumo a/t's, and 3 weeks ago both front hubs (Timken), and had my tires rotated.
I drive highway to work so I'll run 80-90..ish 😈 so it's important that everything holds together. but the other day out of nowhere my steering wheel started shaking and kind of drifting/super sensitive not a plus when whipping in and put of traffic. any ideas why? they checked my tie rods when I put hubs on and said they are good and tight. any ideas it's making me nuts. I am a tire spinner could it be from the tire rotation? is there something else I'm missing?
Old 02-13-2018, 08:47 AM
Roadie's Avatar
Also check the idler arm and the pitman arm. There shouldn't be any up and down movement in those. Recheck the tie rod ends. A balance weight could have come off the rims causing the tire to bounce but that would be more consistent at certain speeds.
Old 02-16-2018, 06:49 AM
enriched's Avatar
Roadie makes a good point...check those 1st.
If this had happened suddenly and just as suddenly the symptoms disappear?? Then I might suggest that snow/ ice had built up inside the rims. Maybe causing the condition, and when temperatures moderated some it melted out.
Old 02-16-2018, 09:53 AM
thanks work in all weekend but will deff check those out. I thought about ice too but it hasn't snowed for about a week I'm thinking it needs balanced again. thinking about putting on a steering dampner I drive some rough washboard gravel daily. looking at the moog one love my moog parts.
Old 02-16-2018, 03:42 PM
wmwright's Avatar
I had the same issue with my 2003 4x4 f150 last year. Felt like the whole truck was going to shake apart especially when I hit a bump. I ended up replacing all shocks, pitman arm, idler arm, inner and outer tie rods, upper and lower control arms with ball joints, wheel hubs and CV axels. I used as many moog parts as I could. I had a true alignment and balance done and I've had no more issues. Drives perfectly now.
Old 02-16-2018, 08:19 PM
wmwright -- you basically rebuilt the front end.
Old 02-16-2018, 08:22 PM
wmwright's Avatar
correct! And it's worth it because now I can keep all of the moog parts greased.made all the difference
Quick Reply: need help shaking in front in but almost all new parts.
