radiator question
Old Jul 23, 2013 | 07:17 PM
Metalguy's Avatar
Radiator Question
I'm wondering if you can replace a single row radiator with a double row radiator? Or if there is not enough room to do it? I've read conflicting information about it, and I'm wondering if you guys can set me straight. I'd appreciate it.
Old Jul 24, 2013 | 12:39 AM
Galaxy's Avatar
Yep! Matter of fact, it's super easy! Matter of fact, it was built for, and used to come with a two row radiator.
Order a radiator for a '97 F250 light duty and it'll slide right in!! That's what I have. THere are a couple of super nice, high quality aftermarket aluminum radiaotors out there if you want to spend the money, but they're pricey. Either way, they'll fit perfectly with no modifications required.
Old Jul 24, 2013 | 10:37 AM
grizzstang's Avatar
Galaxy is right. It is an easy swap.
I changed mine to a two row rad using a Spectra Premium Radiator. It looks like the OEM one and the price is reasonable.
Old Jul 24, 2013 | 12:07 PM
Raptor05121's Avatar
I switched to a dual-core rad when my OEM went out. It was $20 more
Old Jul 26, 2013 | 01:22 PM
It will fit just fine, but if you have a 2003 F150 the trans "cooler" fittings are quick disconnect, and its impossible to find aftermarket.
If you've got an 03 just grab and external trans cooler and reroute the lines into it, and bypass the radiator
Old Jul 26, 2013 | 10:27 PM
Metalguy's Avatar
Thanks guys, I appreciate that. I've got a '99 with a manual transmission. Sounds like the swap should be very simple. That's good news!!
Old Jul 27, 2013 | 07:58 PM
JMC's Avatar
JMC
25 Year Member
It might be difficult to find one for a manual. They don't need the tranny cooler. Don't let that stop you. I bought one for an auto and just left the cooler alone.
Old Jul 28, 2013 | 12:41 AM
Galaxy's Avatar
Don't even bother trying to shop for one with a manual tranny. Just get the radiator and cap the ports for the cooling tank...done. The radiator is the same.
Old Jul 29, 2013 | 08:33 AM
Metalguy's Avatar
I hadn't thought about that. Do they make caps for those ports, or do you need to fabricate your own?
Old Jul 29, 2013 | 02:24 PM
JMC's Avatar
JMC
25 Year Member
The tranny cooler is a tube that sits in the end tank. You don't need to cap the lines. The rad is sealed where the lines come out of the rad for the cooler so the rad will not leak.
Old Jul 30, 2013 | 08:54 AM
Metalguy's Avatar
I see. Thank you.
