Rear sway bar??
Rear sway bar??
I have a 2001 F150 Scab 2wd. I have searched and searched for any info on rear sway bars and I have checked multiple sites trying to find one. On summit I found a few. I found 2 hellwig bars (1 said it was for trucks with a 4" drop), the other hellwig says it is for lightnings. I typed the part #7821 into amazon and it said that it would not fit my vehicle. The other two bars were one made by addco, and one made by belltech. I liked the hellwig bars because they were 1 1/8" instead of only 1". Any input as to which ones would work and which wouldn't? Are there any other ones out there that would work. I dont want to buy the full front/rear set of hotchkis as they are incredibly pricey. Here are the ones I found:
Hellwig 7821 (supposedly only for lightnings)
Hellwig 7856 (For use with 4 in. lowered applications using shackles and hangers.)
Addco 643 (1in diameter, says it will fit all 97-03 rwd f150s)
Belltech 5546 (same as addco)
All I have done suspension-wise at the moment is 2" drop shackles in the rear. That is as low as I plan to go.
Hellwig makes one more for our trucks that is adjustible from 2" lower - 6" higher to stock.
http://www.4wheelparts.com/Lift-Kits...5&t_pn=HEL7621
