Rear sway bar??
Old Jul 1, 2012 | 11:08 AM
Burple's Avatar
It will be a tight squeeze, and you may need shorter end links to get it to be setup correctly
Got a hold of a L rear sway bar, but a bit confused on how to install properly. I've read that it needs to be level to the ground. Looking at the profile it forms a < shape. Which part needs to be level, the one that goes around the diff or the outer part where the end links bolt up?
