My a/c/heat and blower speed lights are not working
i am having a problem with my lights when i turn my parking lamps or driving lamps on you know the the steering wheel controls like cruise,on,off, set acceleration lights up and so does the actual instrument cluster and the headlight swtich and my 4x4 switch does to but my controls heat and air and the speed of the ac or heat isnt lighten up at all? is this a fuse blown or the bulbs are shot?
Is the blower and heat/AC all working correctly?? I mean is low low and high high on fan speed?? If so then the resistor is probly working. I would say check fuses and dash wiring. Funny question - does it help if you slap the dash over the climate control unit? Sometimes a connection can work itself loose and light will work intermittently. Are taillights/running light working properly?? On a bunch of cars, the radio/Climate control lights are tied in with running lights(parking lights) on the same fuse. Anyway, hope this helps, got a few things to check that I have seen numerous times before
