Are those rubber pieces supposed to be cracked and dried like that?
Old Jun 10, 2012 | 01:02 AM
Alex_4.2L's Avatar
I changed the brakes today and noticed this. Also, are the blue plastic things supposed to be cracked like that on the stabilizer bar?
Passenger side
Driver side
Old Jun 10, 2012 | 01:09 AM
AndersonS's Avatar
Those look like replacement swaybar endlinks. Mine are the same color, but the bolt is different. No, they should not be cracked. You can get a new set for less than $20 if ya look a little. Consider replacement.
Old Jun 10, 2012 | 01:11 AM
looks like your upper control arm bushings have seen better days
they appear to be factory upper control arms/ball joints. I would think you're way past due on them.
Old Jun 10, 2012 | 07:57 AM
kingfish51's Avatar
I see you still have the original shocks on. You would help your drive-ability immensely by putting new shocks on, as what you have aren't doing anything right now.
Old Jun 10, 2012 | 10:29 AM
Alex_4.2L's Avatar
Thanks guys I'll do that because right now its riding like a tank. How come there is a grease fitting on one of the balljoints but not the other? Weird...
Old Jun 10, 2012 | 10:58 AM
kingfish51's Avatar
Probably been replaced before.
Old Jun 10, 2012 | 11:05 AM
Alex_4.2L's Avatar
Ahhh well I really appreciate the help guys thanks. Hopefully I can get them replaced next weekend.
Old Jun 10, 2012 | 12:08 PM
str8t six's Avatar
get the control arms and lower balljoints from rockauto. it saved me over $100 getting mine from there.
Old Jun 10, 2012 | 02:10 PM
the debris cover around the upper ball joint is the factory one, on the drivers side
Old Jun 10, 2012 | 04:26 PM
Halverso_99's Avatar
Definitely time for new bushings and shocks.
Old Jun 10, 2012 | 11:37 PM
Raptor05121's Avatar
Not trying to hijack a thread here, but what is the average price for front balljoints?
Old Jun 10, 2012 | 11:53 PM
Alex_4.2L's Avatar
set of front uppers is about 40 bucks I think and the lowers are the same.
Old Jun 11, 2012 | 01:57 PM
03Fx4JD's Avatar
I was going to say the same thing.
Old Jun 12, 2012 | 10:38 AM
1997 lariat 4.6's Avatar
lucky! you have a 2wd... cheaper to do the front end... mine is due and its gonna cost an arm, leg, and a first born child...
Old Jun 12, 2012 | 11:08 AM
Alex_4.2L's Avatar
Mines 4wd and it doesn't cost too much. One hundred for front shocks and one hundred for upper ball joints and control arms. A lot easier if you do the work yourself
