the lift bug
Old Nov 30, 2011 | 11:29 PM
pizzaman711's Avatar
Originally Posted by lltoolj
Youll be fine with the 2'' spacer im running them on mine. I also have a garden hose on top of it for a total of 2.5 inch spacer. My upper control arms are just 1/2 inch from bottoming out. I had to cut off the bump stop on the bottom of the upper control arms for them not to bottom out. u should be good with the 2 inchers
I feel like this question is going to be asked by someone so I might as well get it out the way.. how is it a good/safe idea to stack garden hose on top of the coil spacer?! All that's doing is pushing the coil farther out of the pocket just asking for it to pop out.
On another note, do you have a picture of your ball joint angle? I'd be interested in seeing how close to maxed out they really are. And also how often do you go through ball joints?
Old Nov 30, 2011 | 11:53 PM
lltoolj's Avatar
My ball joint angle could be better. But its ok untill i get the longer uca's
Old Dec 1, 2011 | 12:04 AM
BOOMER2011's Avatar
im going to pass on the garden hose.
Old Dec 1, 2011 | 12:07 AM
Buxton91's Avatar
Boomer you're on the right track. Just fyi, order your coils and UCA's through Canuck Motorsports. It's $380 for the package through them. That's where I ordered mine from and low and behold they were doetsch brand and shipped directly from the doetsch warehouse. Just thought I'd pass the savings along. Let me know if you need to know anything else about the springtech/doetsch kit.
Old Dec 1, 2011 | 12:08 AM
Buxton91's Avatar
Do you really think a garden hose is going to push the coil spring out of the pocket? are you serious? . I have no pic of the control arm but i can tell you it is straight up and down with just about 1/2'' from hitting. Would of never of worked without cutting the bumpstop off the control arm. Never have replaced ball joints. Only have a couple hundred miles since doing it
Please post pics of this nigg rigged ride of yours for all of us to laugh at!
Old Dec 1, 2011 | 12:11 AM
BOOMER2011's Avatar
^ hahahaha made my night!! ha and thanks man, ill check in to taht i may stick with my guy kind of loyal to mom and pop shops. do you have a pic of your truck with 9" of lift on 35s?
Old Dec 1, 2011 | 12:17 AM
lltoolj's Avatar
It looks exactly like yours i just have different wheels and tires
Old Dec 1, 2011 | 12:24 AM
BOOMER2011's Avatar
awwwww sh*t
Old Dec 1, 2011 | 12:32 AM
Buxton91's Avatar
You forgot the part about the ground off bump stops (And garden hoses. I like to leave mine rolled up outside the house.).
Old Dec 1, 2011 | 12:39 AM
Buxton91's Avatar
Here's some with the old wheels and 35's.
Old Dec 1, 2011 | 12:43 AM
lltoolj's Avatar
Ok. good luck with those spring tech spindles. While my coil spacers are snugly and securely in the coil pocket your front tires are rolling away.
Old Dec 1, 2011 | 12:48 AM
BOOMER2011's Avatar
what size tires do you have now?
what size lift is that w/ thos 35s ?
Old Dec 1, 2011 | 12:50 AM
Buxton91's Avatar
This is what it looks like now on the current wheels and 35's.
This is the suspension with doetsch coils and uca's.
And for ****s and gigs, a pic from when I had 37x14's on for a few days.
While I'm at it, Might as well throw up a pic when it was at 8" with 33's.
Old Dec 1, 2011 | 12:51 AM
Buxton91's Avatar
All of the pics except for the last two, I have the doetsch 6.5" suspension lift and a 3" body lift and both sets of tires were 35's.
Old Dec 1, 2011 | 12:55 AM
BOOMER2011's Avatar
i still wanna see this.
@ Buxton why did you take the 37s off?
