the lift bug
Old Dec 1, 2011 | 12:55 AM
  #31
Buxton91's Avatar
Originally Posted by lltoolj
Ok. good luck with those spring tech spindles. While my coil spacers are snugly and securely in the coil pocket your front tires are rolling away.
Obviously you are very misinformed. Every "Real" lift uses some sort of lift spindle. You clearly have no clue what you are talking about.
Old Dec 1, 2011 | 01:00 AM
  #32
lltoolj's Avatar
yea but a real lift doesn't use douche tech spindles
Old Dec 1, 2011 | 01:01 AM
  #33
BOOMER2011's Avatar
the same company that makes PRO COMP, Fabtech and Skyjacker spindles is doetsch.
Old Dec 1, 2011 | 01:05 AM
  #34
Buxton91's Avatar
Originally Posted by BOOMER2011
@ Buxton why did you take the 37s off?
They were really just a temporary set until i found new tires for the wheels. I had no rubbing at all with them, but my rims are 9" wide and 14" wide tires were way too much for them and looked really ballooned. Plus I still hadn't regeared so it was very sluggish to say the least.
Old Dec 1, 2011 | 01:06 AM
  #35
Buxton91's Avatar
the same company that makes PRO COMP, Fabtech and Skyjacker spindles is doestech.
Like i tried to say before, a very misinformed idiot.
Old Dec 1, 2011 | 01:08 AM
  #36
BOOMER2011's Avatar
oh okay. i see i see. i may keep my 35s for until i need new tires. since i just bought theses. and ill have some more wheel travel
  #37
BOOMER2011's Avatar
yea
Old Dec 1, 2011 | 01:10 AM
  #38
lltoolj's Avatar
whatever
Old Dec 1, 2011 | 01:14 AM
  #39
BOOMER2011's Avatar
IT IS DOETSCH.
yea i just pulled that info out of my butt. if DOETSCH doesn't make their spindles than who does? you? with your garden hoses?
  #40
Buxton91's Avatar
I thought i was the only jackass here
Don't worry, you still are.
Now please quit ruining this guys thread.
Old Dec 1, 2011 | 01:16 AM
  #41
Buxton91's Avatar
IT IS DOESTECH.
yea i just pulled that info out of my butt. if doestech doesn't make their spindles than who does? you? with your garden hoses?
Hey now, don't be hating. I hear you can get an extra half inch by stacking garden hoses. All you have to do is grind the bump stop off of the UCA's so it quits banging the springs everytime you hit a pot hole.
Old Dec 1, 2011 | 01:20 AM
  #42
BOOMER2011's Avatar
HAHAHAHAHAHAHAHAHAHA oh im crying i need oxygen !!!!!
Old Dec 1, 2011 | 01:25 AM
  #43
Buxton91's Avatar
I see you went back and edited your previous post Sir Tool. If you've never seen these spindles in person, then you have no room to talk. They are massive and way more solid than the puny ones from ford that I took off the truck. As for crumbling and snapping, I've jumped a cattle gap going 40 mph one very late night and none of that happened to me. I guess I must of just found a golden set then.
Old Dec 1, 2011 | 01:26 AM
  #44
BOOMER2011's Avatar
so back on topic i think while i have the front end torn a part i thin im going to pain my lower A-arms and sway bar and stearing hardware with spray coating and know off the build up of road grime and dirt, maybe i could barrow his hose. or i may to to scrap yard and get a nother set and just paint and swap what do ya think?
  #45
lltoolj's Avatar
I think its a good idea to paint those parts.. i just painted my rear axle and frame.. looks good
