Bi-xenon hid high/lo problem
Old Nov 14, 2011 | 10:30 PM
harryb5a4's Avatar
I have a 2002 ford f150 with daytime running ligts. I recently installed a bi-xenon hid kit. The low beams work fine but when you switch from high to low there is no change visually in the lights. When you look at the dash with the low beams on the high beam indicator is dimly lit. When you flip to high beam the indicator lights all the way up. I purchased the kit that comes with the relay and all. If anyone can please help me with this issue I have I get my truck inspected in a few days and have no high beams. Thanks
Old Nov 15, 2011 | 12:10 AM
rednutbow's Avatar
Your wires are backwards. The 9007 plug is shared with a 9004, your kit should have instructions on how to flip the wires.
Old Nov 15, 2011 | 08:31 PM
harryb5a4's Avatar
Already flipped the wires at first the highs were stuck on and then after we switched the wires the low beams Started working but still when u switch from low o high inside the truck the bulb itself will not switch.
Old Nov 15, 2011 | 08:45 PM
pizzaman711's Avatar
Ebay style hid kit? Could be the cheap chinese bulbs aren't retracting, aka you get what you pay for basically.
Old Nov 15, 2011 | 10:10 PM
Raptor05121's Avatar
yup. plus the relay harness itself sounds like it has problems (ie backfeeding)
Old Nov 16, 2011 | 01:15 AM
rednutbow's Avatar
I promise you that youre ground wire is on the wrong place... I went through this, if you would have searched you would see this question has been asked before! BY ME!
Old Nov 16, 2011 | 06:43 AM
harryb5a4's Avatar
its actually not a cheap it it was $188 dollars i figured it was a decent kit....rednutbow to be honest i did search for a couple hours on this but found it was mostly for the next generation truck. So you think i need to check my grounds on the kit and make sure that everything is grounded good.
Old Nov 16, 2011 | 04:30 PM
rednutbow's Avatar
Alright, but I sent my kit back... just to find out that the directions were wrong and the ground prong was in the wrong location. Get a multi meter and check what is +12V hi/low, then the 3rd wire is ground. Thats what I ended up doing, and it been working good since.
David
Old Nov 16, 2011 | 05:09 PM
sorry dude, you most likely got scammed. Just about all aftermarket HID kits are made from the same factory in china and sell for about $30-$40. For a few bucks more, you could've done a proper retrofit with bi-xenon projectors instead of silly PnPs
as far as the problem goes, go double check the wiring. A DMM would definately help in this case.
Old Nov 16, 2011 | 07:32 PM
mxmike800's Avatar
im saving for 100w 6ks hi / lo for the truck. i cant wait to see what those will do!
Old Nov 17, 2011 | 06:37 PM
ParnAZ's Avatar
Well 100W is almost twice the wattage of stock so hopefully nothing melts...
An oem HID system only uses about 35 watts and is around 4300k. Anything more than that and you start to lose visible light (further and further off the spectrum). Personally if I was install HIDs it would be a retrofit from an OEM bi-xenon projector i.e. 04+ Acura TL. Those FX-R systems look pretty nice also.
Know what your getting into and be careful with the wiring.
Old Nov 17, 2011 | 08:32 PM
well first off, those "100W" ballasts only put out about 60W of power. secondly, you are more than likely going to burn something up, and dont get me started on glare.
Old Nov 2, 2013 | 01:48 AM
azexploder's Avatar
Lightbulb Bi-Xenon no hi P-(
Who knew. $40 chinez bi-xenon without directions.
  1. 10 day delivery, nice box - bad engrish.
  2. 15 min to install, No HID love.
  3. 30 min to read all the ground wire and socket wire swap posts
  4. 2 min to swap the socket wires and BAM..
Hi/Lo HID Dazzle.
White - low
Blue - hi
other - ground
1998 Expedition
