For those with LEDs in tails
Old May 8, 2011 | 11:32 PM
migdaddy's Avatar
Some guy on ebay who's sold 20k products. I took a chance.
Old May 9, 2011 | 09:14 AM
Raptor05121's Avatar
ouch
Old May 9, 2011 | 06:55 PM
Red02FX4's Avatar
ouch
Ouch.... what? (just wonderin')
Old May 9, 2011 | 09:24 PM
he took a chance and he got bitten. i never buy lights from eBay unless they are confirmed OEM
Old May 11, 2011 | 03:33 AM
Red02FX4's Avatar
gotcha
Old May 11, 2011 | 09:42 AM
DanielWalker10's Avatar
Originally Posted by blitz_
A LED 3rd brake light wont cause your cruise control to go out. It has nothing to wo with it and its not even on the same circut so i dont see how that can even be the case.
i call BS on that statement. i had to install a resistor, the small one (i forgot the numbers) to get my cruise control back when i put my recon third brake on and even my cheap ebay one. also without the resistor my recon would stay just barely lit when all other lights where on.
Old May 16, 2011 | 03:53 PM
blitz_'s Avatar
I used my cruise control just this afternoon and i have a led 3rd brake light. but my truck is a 03. did have a 00 with the smae light and no cruise problems.
Old May 17, 2011 | 01:43 PM
RSchnier's Avatar
A LED 3rd brake light wont cause your cruise control to go out. It has nothing to do with it and its not even on the same circut so i don't see how that can even be the case.
For what it's worth, here's the relationship. The cruise control computer won't let you engage if it senses a problem with your brake lights (apparently for safety reasons). An LED doesn't present a low-enough resistance (compared to an incandescent bulb) for the computer to be able to tell that it's not your brake light bulb just being burned out. Adding a so-called "load resistor" in parallel with the LED, fools the computer into thinking you have an incandescent brake light bulb in working order.
Old May 18, 2011 | 09:31 PM
blitz_'s Avatar
I dont have a resistor on it, i just took down the headliner, unplugged and unscrewed the old one and plugged in and screwed the new one. i put everything back together and it worked with no problems. Your CC wont work under 35 mph but thats just common sense stated in the owners manual.
Old May 18, 2011 | 10:42 PM
Red02FX4's Avatar
Ditto. I don't have a resistor on my Recon LED 3rd either. Just plug n play (and has always work fine... as well as my cruise). I do have resistors for my front LED turn bulbs, to eliminate the "fast flash"
Old May 19, 2011 | 01:20 AM
Recons come with vRegs & load resistors on them
Old May 19, 2011 | 08:04 PM
Red02FX4's Avatar
didn't know that.... but would explain the slightly higher price, aside from better quality I suspect
