CB Pics
Old Mar 29, 2011 | 07:48 PM
str8t six's Avatar
you could get one that mounts in the stake hole.
Old Mar 29, 2011 | 09:54 PM
FordGuy24's Avatar
Believe it or not...my bed doesn't have stake holes
Old Mar 29, 2011 | 09:56 PM
Red02FX4's Avatar
Originally Posted by FordGuy24
Hey guys...I've always wanted to put one in mine but not sure about what to do for the antenna...what do all of you do? I don't want anything mangnetic on my paint or wires showin everywhere
I have a fiberglass bed top that I drilled a hole to mount. Ran the cable under and into the cab .... under the carpet... to the CB
The antennae doesn't come close to hitting the roof
Old Mar 29, 2011 | 10:02 PM
Raptor05121's Avatar
Some of you guys have messy wiring. Not a CB, mines a VHF transceiver for the fire dept, but here ya go:
double
1998f150wes's Avatar
hey i just ordered a cobra 29 LTD on AMAZON and a 4' whip what kinda range do you think i could get 4watt CB with 900watt Antenna
Old Mar 29, 2011 | 10:06 PM
a mile or two tops
Old Mar 29, 2011 | 10:08 PM
why so little
Old Mar 29, 2011 | 10:13 PM
its a regulated 4watts and you only have a 4 antenna. it could be a bit higher, but i wouldnt guess much without an amp
Old Mar 29, 2011 | 10:17 PM
Buxton91's Avatar
I wonder if there is some sort of clamp on mount that doesn't require drilling into the bed? Or get a tool box, problem solved!
Old Mar 29, 2011 | 10:18 PM
thejake1989's Avatar
agreed
Old Mar 29, 2011 | 10:22 PM
what would it be with an amp and where at and how much are they
This is the antenna i ordered
http://www.walcottcb.com/firestik-fs....html?cPath=28
Old Mar 29, 2011 | 10:38 PM
What i do is i have the antenna wire running under the carpet and have the antenna base sitting under my rear seat and the antenna in the toolbox. When i need to use it i put the antenna on a thin piece of cloth and put it on the roof. That away i dont scratch the paint. I dont use my cb all the time just on extended road trips
Old Mar 29, 2011 | 10:39 PM
Originally Posted by Red02FX4
Off topic but i love your truck
Old Mar 31, 2011 | 10:06 AM
03Fx4JD's Avatar
Sorry the second one is a little blurry...
