CB Pics
Old Mar 31, 2011 | 06:15 PM
  #31
ford4life.'s Avatar
changing location soon.
Old Apr 1, 2011 | 08:35 AM
  #32
1998f150wes's Avatar
everyones got theres in the same place but i got a question what is a good tip for running wire under the carpet. could i tape the wire to the end of a coat hanger or what give me some ideas cause i dont like sloppy installs
Old Apr 1, 2011 | 11:07 AM
  #33
jtwoodall's Avatar
Pull off those plastic trim pieces at the bottom of the door and you can pull up the carpet from there. Run the antenna wire around the drivers seat and up towards the middle and back up and out through that black plastic thing under the middle of the dash.
As far as powering the CB I took the 12v plug they gave you and cut off the adapter on the end leaving me with the two wires, + and -. I ran those back up through that same black thing, across the pedals (under the carpet) and up through the fuse box. Took out the radio fuse (only hot with key in) and put the red(+) in the fuse slot, then shoved the radio fuse back in. (You could always buy one of those inline fuse things, but this just works just as well) and then took the black(-) and wrapped it around one of the screws just below the fuse box. I did the same thing for my radar detector, so I have a cb, radar detector, pa, etc with no wires or those annoying cords laying around my truck.
Old Apr 1, 2011 | 12:03 PM
  #34
str8t six's Avatar
i pulled up the plastic on the drivers door and ran it in the channel to the back through the cab vent to the bed.
for the power, i tapped into the cigarette lighter in the fuse panel.
Old Apr 1, 2011 | 05:35 PM
  #35
okay i just got my antenna and coax today and my coax is to big for the connector on the whip is there an adapter i can get or make
Old Apr 1, 2011 | 08:46 PM
  #36
str8t six's Avatar
they connect to each other through whatever mount you get. they dont connect directly to each other.
Old Apr 1, 2011 | 10:30 PM
  #37
^ thanks man were can i get a mount
Old Apr 1, 2011 | 10:48 PM
  #38
str8t six's Avatar
truck stop, radio shack, internet..
what kind you want to get?
Old Apr 1, 2011 | 10:51 PM
  #39
str8t six's Avatar
i used one like this
http://www.walcottcb.com/firestik-m2...ath=28_353_431
you can see where the coax and antennea connect together on the mount.
Old Apr 2, 2011 | 12:03 PM
  #40
fordordie1's Avatar
ill play...since this pic i have wired the coax and power throught the headliner and a piller/fame and got er all rigged up
i like where it is, got one of those retractor mic holders
Old Apr 2, 2011 | 09:32 PM
  #41
Originally Posted by jtwoodall
what did you make the antenna adapter out of
Old Apr 2, 2011 | 11:09 PM
  #42
jtwoodall's Avatar
I didn't, it came with the horizontal mount. Picked it up at a local truck stop (Love's I think)
http://www.rightchannelradios.com/mi...-stud-454.html
Just got something like that and only used the top half.
What im looking to get is one of these bad boys, you just fold it down when you don't want it.
http://www.walcottcb.com/antenna-fol...3ez-p-262.html
Somebody stole my fiberglass antenna so I keep my spare one in my box along with the magmount. Im thinking about getting that fold over adaptor so it lays down between my back window and box when I don't need it and its out of sight.
Old Apr 2, 2011 | 11:47 PM
  #43
what size do i need for my antenna
http://www.walcottcb.com/firestik-fs....html?cPath=28
and my coax
http://www.walcottcb.com/rg8x-coax-c...l?cPath=28_355
Old Apr 3, 2011 | 01:06 PM
  #44
jtwoodall's Avatar
Your antenna base is 3/8"-24 base. The fold over adaptor I posted has a 3/8" adapter on top and bottom. And I'm pretty sure that most of the coax cables are the same type (PL-295). If you want a mount like mine I would purchase something like this http://www.walcottcb.com/hm1-horizon...ath=28_353_436 So if you buy the antenna you posted (http://www.walcottcb.com/firestik-fs....html?cPath=28), the adaptor I posted (http://www.walcottcb.com/antenna-fol...3ez-p-262.html), and the coax cable (http://www.walcottcb.com/rg8x-coax-c...l?cPath=28_355) you will be good to go.
I would call Walcott's number just to double check. 1-563-284-6051
You can also walk in to any truck stop around Edmond and pick up the same parts there.
Old Apr 3, 2011 | 05:28 PM
  #45
well i went to radioshack and got my adapter for my antenna, and got it installed. the one i is the mirror mount one and just took off the back plate and went from there.
