Coolant leak
Old Mar 19, 2011 | 06:36 PM
Stephen87's Avatar
Coolant leak
I think that is what I have since my dads truck overheated today and when I opened the hood there was steam shooting from what looked like under the intake manifold and behind the alternator. Is it the heater hose that is uner the manifold and also is there a way to bypass it for a quick fix or do I have to remove the manifold to get to it(if so is can someone tell me how to do it
fyi it is a 2000-01 f150 with a 5.4
Old Mar 19, 2011 | 06:50 PM
sniknah's Avatar
Head gasket ?
Old Mar 19, 2011 | 07:06 PM
Stephen87's Avatar
I hope to God not
Old Mar 19, 2011 | 07:10 PM
sniknah's Avatar
Could you see the leak? was it down below the engine or up above where the valve covers are?
Old Mar 19, 2011 | 07:20 PM
jbrew's Avatar
Yep, O-rings went bad on the water pump stem, -there's two. It's either that or the manifold cracked. The model years 2000 was the first year of the composite for the 5fours. They would crack, passenger side front water jacket.
UNLESS! I doubt it , but, Ford did use a small heater hose connection behind the pumps on their reman blocks. If that's a factory re-manufactured block, then it's a heater hose most likley. Other than that, it's a hard line that slides over the water pump stem with two O-rings.
You'll obviously have to pull the manifold. Even if it is a hose or O'rings, make absolutely sure the manifold didn't crack. Allot of them do.
Old Mar 19, 2011 | 07:49 PM
Stephen87's Avatar
well I looked into it with a flashlight and I couldn't find any immediate cracks but I did see coolant on the passenger side fuel injectors what would that tell you
and as to whether it was reman or not I dont think it was since we bought it brand new off the lot
Old Mar 19, 2011 | 08:00 PM
jbrew's Avatar
Sounds like the manifold. If it is you'll need a new one. There's no fixing that one. A used 03 composite or 99 Aluminum manifold is choice for used. The 03 composites are made from better materials.
Used: Go here and type in your zip to find one close to home -
http://car-part.com/
Other than that, - dealership or dorman has them as well.
Old Mar 19, 2011 | 08:06 PM
Stephen87's Avatar
sounds good(well not good) looks like I have my work cut out for me
Old Mar 19, 2011 | 09:00 PM
Toyz's Avatar
Yeah, like Jbrew said, either check in the valley under the intake manifold where the water pump stem is, or the intake manifold. It typically cracked near the passenger side where the composite meets the metal cross over. Either way, the intake has to come off. Simple job and a good time to clean the throttle body and elbow, IAC, change the plugs and clean things up. If you have any questions on how to remove those things, it's pretty straight forward. A good tip is to clean things as best as possible before you remove anything, using compressed air. Don't want debris falling down into the heads or anything. Also is to make sure and relief the fuel system when removing the fuel rail and have some rags handy to catch spilt fuel. Otherwise, it's just unbolt and remove things. When you get to the point your ready to reinstall, there is a torque sequence for the intake manifold that is very important. But for now, find the leak and go from there.
Old Mar 20, 2011 | 07:33 PM
Stephen87's Avatar
well I was able to fill the tank back up with coolant and leak sealer and then drove the truck the hour drive back home and it did not over heat or leak coolant, I also put a dye in there so I am going to keep an eye open and see if I can find something
Old Mar 21, 2011 | 03:59 AM
Stephen87's Avatar
also found out the proper year for the truck on the sticker on the door it says 09/01 but on the insurance it says 2002
Old Mar 21, 2011 | 09:20 AM
Raptor05121's Avatar
dont use coolant sealer- i did and it clogged my heater core and radiator. my truck overheated for a while before I spent $200 on a new radiator. i still dont have heat
Old Mar 21, 2011 | 09:34 AM
jbrew's Avatar
Yea, that's stuffs nasty... It'll cost you more $$$ in the end.
Old Mar 21, 2011 | 12:48 PM
Stephen87's Avatar
I guess I better get flushing it out
Old Mar 21, 2011 | 01:02 PM
jbrew's Avatar
You can try that, you may get some of it out, I doubt you'll get it all. Still, it's a good idea to try IMO.
