Lsd to posi
Old Feb 24, 2011 | 07:41 AM
zackn's Avatar
Hey I just thought of a question.. What are the other axle codes and what do they mean? If either of u guys know.
Old Feb 24, 2011 | 09:32 AM
ChrisT's Avatar
Let me search that for you!
15 = 3.73 non LS
19 = 3.55 non LS
26 = 3.73 non LS
27 = 3.31 non LS
B6 = 3.73 LS
H9 = 3.55 LS
L6 = 3.73 locker
8.8 front 28 splines
8.8 rear 31 splines
9.75 rear 34 splines
Old Feb 24, 2011 | 11:30 AM
zackn's Avatar
15 = 3.73 non LS
19 = 3.55 non LS
26 = 3.73 non LS
27 = 3.31 non LS
B6 = 3.73 LS
H9 = 3.55 LS
L6 = 3.73 locker
8.8 rear 31 splines
Your a swell guy chris. Your a swell guy.
My only internet use is on my blackberry. I would search if it wasn't a pain in the ***. Much appreciated!
Old Feb 24, 2011 | 11:33 AM
ChrisT's Avatar
You're welcome.
Old Feb 24, 2011 | 11:58 AM
Veteran: Army
Hey guys Im just curious what I need to get when switching from lsd to a posi carrier?
so you want to swap from a Ford term to a chevy term
Old Feb 25, 2011 | 09:45 AM
zackn's Avatar
Ya lol. We all start somewhere haha. Anyway, I just called my mom and got her to check my axle code and its... 27 3.31 non ls.
Do you guys think it would be a good idea to go to a wrecker and find an ol ford with a 8.8 ls diff and just rebuild it? Or buy a brand new diff from summit or something like that ?
Old Feb 25, 2011 | 09:59 AM
zackn's Avatar
Also, if I do go find a 31 spline 8.8 ls diff from a truck at a wrecker.. Will it bolt right in my truck?
Old Feb 25, 2011 | 10:03 AM
phil6608's Avatar
I would just get the new one. It's only about 200 bucks.
http://www.summitracing.com/search/?...erential&dds=1
Phil
Old Feb 25, 2011 | 10:40 AM
zackn's Avatar
Would my open diff gears work on the limited slip diff ?
Basically I wanna know if everything from my open diff except the carrier. So gears, pinion, spider all that sheet.. Will it work on the ls carrier?
Old Feb 25, 2011 | 11:19 AM
phil6608's Avatar
Your spiders and all that sheet will already be in the new diff.
You just bolt your ring gear to the new diff and your pinion stays the same too.
Old Feb 25, 2011 | 01:14 PM
zackn's Avatar
That's simple. Thanks
Old Feb 25, 2011 | 01:39 PM
Klitch's Avatar
get a locker like a eaton tru trac or a detroit locker or a aussie locker.
Tru-Trac is a helical gear LS. Correct?
Old Feb 25, 2011 | 01:41 PM
Klitch's Avatar
Note: Check backlash, don't just slap er in and dry your hands off.
Old Feb 25, 2011 | 01:59 PM
phil6608's Avatar
Yeah,
I guise I should of added that in.
If your going to do it yourself and have never done it. You will need special tools and you better do a lot of reading up on it before you even attempt it.
Ive never done one but It's a pretty technical job.
Phil
Old Feb 25, 2011 | 03:05 PM
Klitch's Avatar
Time consuming, and attention to details.
Someone else posted this somewhere recently, I like it, good overview of whats entailed.
http://www.pirate4x4.com/tech/billavista/Gear_Setup/
