Help already changed thermostat
Old Feb 3, 2011 | 12:17 AM
casest7's Avatar
Even though my truck is not overheating, the temperature gauge will shoot up to hot and the oil light will come on. After a few minutes, the truck will not let me accelerate anymore. If I shut the truck off, it will reset the oil light and the temp gauge and run fine for a while. But eventually, it will do the same thing again. Is it a sensor or computer problem
Old Feb 3, 2011 | 02:43 AM
autotech88jtaw's Avatar
try replacing your cap on your coolant resevior tank, thats what was causing my overheating cause it couldnt release the pressure, or if you want to make sure that its your cap on your tank, just crack the cap open a tiny bit and see if the problem persists
Old Feb 3, 2011 | 09:52 AM
BLUE20004X4's Avatar
Maybe a dumb question but did you fill up the coolant properly? Then, burp it? You can leave the cap off. Why the oil light comes on, hum???? Sounds like your truck is in limp mode when the coolant temp goes up. Your oil pressure switch might be f'd too.
Old Feb 4, 2011 | 11:48 AM
casest7's Avatar
ok I changed thermostat, filled it with coolant, changed the fan clutch, and water pump amd and it still overheating sitting idle it gets ut too when i drive it overheats instantly, what next.
Old Feb 4, 2011 | 11:57 AM
motoman288's Avatar
is the computer throwing any codes?
and may try changing the water temp sensor on the intake. it maybe tyellin your computer that something isnt right and then the computer is shutting the truck down
And i wanna say its on the side of the block maybe? but there is an oil temp sensor down there somwhere( i knoiw this cuz i broke it off puttin my motor back in last week=()
May try that also
Old Feb 4, 2011 | 12:07 PM
TJ8769's Avatar
probably faulty sensors giving wrong info wich sounds likley since you can shut it off and turn back on and be fine again. id replace the oil pressure switch and the coolant temp switch and see if it fixes it.
Old Feb 4, 2011 | 12:08 PM
casest7's Avatar
No its has no codes at all i was just messing with it again and as soon as I turn it off and turn it back on its right back at normal temp IM CONFUSED
Old Feb 4, 2011 | 01:08 PM
JMC's Avatar
JMC
25 Year Member
Failsafe cooling mode will peg the needle and turn on the oil pressure light. When it overheats is the coolant really hot? A faulty CHT ( Cylinder Head Temp) sensor will cause this. Does the degas bottle overflow?
Old Feb 4, 2011 | 02:06 PM
casest7's Avatar
No the coolant isnt hot what is the degas bottle?
Old Feb 4, 2011 | 02:39 PM
JMC's Avatar
JMC
25 Year Member
The overflow bottle with the rad cap. So if the coolant is not hot and this is happening it points towards a defective CHT sensor. Year and engine of your truck?
Old Feb 25, 2011 | 06:31 AM
Mugsy's Avatar
Hi your not alone, I seam to be experiencing a similar problem with my 91 5.0. I;m a motorcycle mechanic instructor so I;m no novice, but not a ford tech either. Heres the deal. recently while driving the truck it takes a short time to warm up, occasionally though my temp gage will rise almost out of the operating range then suddenly drop to normal. I have noticed it tends to do this under light throttle applications, if I pick up the rpm to oh about 2K the temp drops in a matter of a few seconds. The only things not replaced in the last year in the cooling system was the water pump and the lower hose. Question, has any one had problems like this, and/or has any one had a pump impeller come loose on the shaft? Thinking must be the latter! Stay tuned I;m going to change the pump and lower hose today.
