Air pocket in the coolant system?
Old Dec 19, 2010 | 04:10 PM
mcolford's Avatar
So heres what I got,
1998 with the 4.6L. Got a new thermostat (OE) put in, a coolant flush a couple weeks ago,...
After truck is running temp, my heat is kinda warm, but not that nice and toasty. If I turn the heat off for a couple minutes, then turn it back on, its hot for a bit (15-20 seconds roughly) then back to the warm.
Sound like an air pocket in the heater core? What do yall think? And if it is how the hell do I get it out?!?!?!?!
-Matt
Old Dec 19, 2010 | 06:15 PM
torkum's Avatar
Did you buy a Motorcraft replacement thermostat with the bleed hole?
Old Dec 19, 2010 | 07:02 PM
MuddYMesS's Avatar
sounds like you need to burp the cooling system. i do not have time to right a how-to, but they are al over google. just type in burping f150 cooling system. sorry about the how to have to be at work....good luck
Old Dec 19, 2010 | 08:44 PM
mcolford's Avatar
I have also read about putting a valve inline by the heater core for flushing... Anyone got any ideas on that?
Something like this..
http://www.oreillyauto.com/site/c/de...0185&ppt=C0075
-Matt
Old Dec 19, 2010 | 11:50 PM
Raptor05121's Avatar
Open the degas bottle, run the engine to closed loop and heater on max. As the thermostat opens, use a shop rag and squeeze the water return pipe. Air will escape out of the degas bottle
Old Dec 20, 2010 | 01:12 AM
mcolford's Avatar
Raptor.. What is the closed loop setting?
Old Dec 20, 2010 | 02:18 AM
Warmed up.
Old Oct 19, 2012 | 10:07 PM
JHL's Avatar
JHL
Question
Raptor:
I realize this is an older thread, but should you shut off motor once the engine reaches operating temp and the thermostat opens or leave it running?
Doesnt seem like it would matter once the thermostat is open, and safer with it off...
Old Oct 23, 2012 | 09:11 AM
Basically warm up, heater max heat, also easiest to lift the front end up to help get air trapped in the top of the heater core
Old Oct 26, 2012 | 08:27 PM
jbrew's Avatar
Right, -allot cleaner as well. The 4x4s get a little high before they level off. Unless you remove the rear wheels and drop it first lol.
Old Oct 26, 2012 | 09:34 PM
jethat's Avatar
I just do it in my drive way thats got some tilt to it but the higher the radiator the better. Air flows up.
Old Oct 29, 2012 | 12:28 PM
JHL's Avatar
JHL
Do I bleed off air with engine running or off? Seems like once the thermostat opens it wouldnt matter. I do have a 4x4, so I will have to jack up front end or lower rear end to do this!
