removing headlight switch
Old May 17, 2010 | 12:02 PM
F150man21's Avatar
Question removing headlight switch
i have a 2000 f150 with an intermittent odometer. i have found the threads to fix my odo but i can remove my headlight switch. the **** does not pop off and i tried to find directions with the "newer" switch removal but could not find any. is there a video or pics of a how too?
thanks fellas
Old May 17, 2010 | 12:37 PM
kingfish51's Avatar
Turn the headlight switch to the on position and pull out like turning on the fogs. This should allow you to see a small hole that you can insert a paper clip or very small screwdriver and allow you to remove the ****. Turn the **** 180 degrees in put it back on. This will allow you to continue to turn the **** which will cause what looks like a door latch to pull inwards and you can remove the switch assembly.
Old May 17, 2010 | 12:42 PM
F150man21's Avatar
i cant remove the ****, it does have that little notch under it but i can pry it pretty hard and it wont come off. there are a "newer" version of these headlight switches that require a different strategy. i need those instructions.
thanks
Old May 17, 2010 | 06:47 PM
jtwoodall's Avatar
I have the same issue as you, there is a little notch I promise you, but you have to pull on it pretty hard to see it. I managed to get the **** to pop off and spun it 180. Problem is that when you pull on it just the **** comes off, not the entire assembly. And now my know will fall off when I barely touch it. Might want to try prying the entire thing off with a screwdriver if you are not afraid of a scratch or two.
Old May 17, 2010 | 10:54 PM
Raptor05121's Avatar
Here you go:
http://s89.photobucket.com/albums/k2...=MOV02935.flv]
Old May 18, 2010 | 08:15 AM
F150man21's Avatar
yea i saw that video and tried it. its not coming off easy at all. thats why i'm insisting that i have the NEWER version with the 3 clips. this "NEWER" version is the kind i need help with.
Old May 18, 2010 | 08:32 AM
thejake1989's Avatar
the 99+ switch just pops out by prying with a screw driver at the top and bottom of the switch body itself. try that. you may think your gonna break it though but should pop out
Old May 18, 2010 | 02:57 PM
F150man21's Avatar
so the whole unit just pops out? that seems sketch but ill give it a shot.
thanks
Old May 18, 2010 | 04:22 PM
Dinggus's Avatar
F150man21, trust them it works.
Old May 18, 2010 | 07:25 PM
yeah its all the same basic design
Old May 19, 2010 | 09:50 PM
you get the switch out?
Old May 20, 2010 | 01:50 AM
fairlaner's Avatar
My '03 work truck has a little slot on the bottom of the switch assembly where it looks like you could use a screwdriver to pry the switch out.
Old May 20, 2010 | 02:55 AM
GATOR CREW's Avatar
2009 F150online Truck of the Year
I had a write up on another site, but for some reason, can't find it....here are 2 pics for you from when I removed my switch....the first shows the side and top clip...the last shows where the bottom clip is located.
It is pretty easy to remove, just make sure you use a small flat head. Btw, I wrapped it in a couple layers of tape(blue painters tape) so I wouldn't mark up the switch
Hope this helps
Old May 20, 2010 | 11:41 AM
F150man21's Avatar
not yet, i've been busy as hell at work and have not had time. this weekend i'll give it a try.
Old May 20, 2010 | 11:43 AM
F150man21's Avatar
thanks gator crew, those pics will really help... no pun intended
