Lumbar Support Not Working?
The **** spins, but doesn't move the lumbar support. (It used to work, but has quit.) Before I tear into this blindly, is there a common cause for this? Any hints/tips for troubleshooting and repair? The factory manual doesn't seem to address it.
Thanks in advance.
Andy
Thanks in advance.
Andy
Didn't think to look outside of the 97-03 section. Still didn't find much info. I was hoping for a detailed "this is what usually happens, and this is how to fix it" solution. Guess I'll have to tear it apart and see what my specific issue is.
Thanks.
Andy
Thanks.
Andy
Did ya see these threads?
https://www.f150online.com/forums/in...r-support.html
https://www.f150online.com/forums/in...rt-broken.html
Sounds like you will need to remove\separate you seat back from your seat cushion to gain access to the cable, which is most likely the culprit. Good luck.
Andy
