Efan brackets
meh. I would like to replace the condenser anyway, its banged up and fins are bent. it wouldnt hurt to replace it and i found one for $90, problem is I have to discharge my brand-new A/C system, and remove my brand-new radiator
shouldnt have to completely remove the radiator, just pull the upper mounts, and pull it out of the bottom mounts and bend the hoses and slide it back enough to get the condenser out.
but yes you will need to discharge using a proper vacuum recovery machine for the AC system
hey pat, I've got two 5/16" threads for that second core for what I believe is a trans cooler for the automatic trucks? what could I route through there to put it to good use?
Well, I'm going to bring this thread back to the top. It seems to be the best detailed for somebody looking to build their own kit.
Reading through here, it seems fairly straight forward; two fans (5,000 cfm atleast), brackets, and a controller.
I think that I will attempt this sometime in the near future, but I'm not crazy about having a switch in the cab. Why exactly is an over ride switch needed with a temp controller?
Buy two 16" fans. I got mine from eBay, make sure they have lifetime warranties!
I have the Hayden-Imperial 30A controller from Advanced Auto.
And 2 strips of aluminum brackets and a bunch of nuts and bolts from autozone.
If you want to do this (not dissin' Alex or Pat here), you may want to be aware of some other alternatives.
www.dccontrol.com
www.spalusa.com
This is not something where cost is supposed to be the primary consideration. Wiring practices are of utmost importance. And all fans are not created equal. The same goes for controllers - proportional control (where turn-on is 'soft' and fan speed tracks coolant temperature) is very beneficial over a simple on/off device.
There are reference schematics within those links as well.
I am also an advocate of manual overrides and in-cab indicators. The Controllers listed above embrace both.
Some more good info in this thread: https://www.f150online.com/forums/to...ng-e-fans.html
Good luck.
MGD
where are you guys finding the dual core radiators? and whats the pn#. i think my internal trans cooler is leaking into the radiator as the coolant is a funny color in the over flow bottle so ill upgrade to a dual core radiator and external trans cooler. any suggestions on trans cooler as well?
Mr.Scooter;
www.dccontrol.com
www.spalusa.com
Good luck.
MGD
www.dccontrol.com
www.spalusa.com
Good luck.
MGD
If you want I can make you a wiring diagram
i know this thread is a little old raptor but did u ever mke a wiring diagram? really interested in using this setup, and does ur temp gauge in you truck fluxuate any in stop and go traffic? any info would be appreciated
