Efan brackets
Old Mar 9, 2010 | 09:02 AM
Originally Posted by 97XL
Great..I was concerned about them not pulling enough without a shroud. Thanks Pat.
Ive done heavy towing with my Efans and havent even come close to overheating w/o a shroud, and they do fine in the 105+ summer days with AC on max too.
Rapt..looks good..you going to paint the strips? I was thinking of painting mine black or putting POR15 on them to help with rust protection.
Aluminum doesn't rust
Looking good Alex, but one thing, You're a damn copy cat
Old Mar 9, 2010 | 03:46 PM
Raptor05121's Avatar
Just wait until I get my STX valance and L wheels
Old Mar 10, 2010 | 12:39 AM
97XL's Avatar
Thanks Pat..it doesn't get that hot here so I should be good. For some reason I had the thought that the brackets were steel duh!!.
I was thinking of mounting my fan controller either on the firewall or inside the cab to give it better water/temp protection.
Old Mar 10, 2010 | 01:22 AM
Gotta love aluminum: lightweight, strong, easy to manipulate and fun to work with!
The controller is water sealed already. Unless you are worried about the plastic casing and wire insulation getting wet, your wasting your time.
Old Mar 11, 2010 | 12:17 AM
motoman9191's Avatar
I've been researching this set up with the aluminum bars and like it a lot. What kind of fan/ controller/ etc are yall using if ya dont mind someone copying your set up
Last edited by motoman9191; Mar 11, 2010 at 12:24 AM. Reason: bad spelling, good thing im not an english major
Old Mar 11, 2010 | 12:48 AM
Hayden-Imperial 30A
$34 @ AdvancedAuto
bought my fans off eBay. Im around 20K with them and almost a year and a half
Old Mar 11, 2010 | 01:06 AM
97XL's Avatar
Rap...do you remember who got the fans from? What is the Amps at startup&running?
Old Mar 11, 2010 | 01:20 AM
No. basically they are all the same. I bought from two different sellers and they are the same exact fan. just make sure you buy from someone with a warranty.
dunno the amps at startup, but I have both on a 30A relay and everything is fine
Old Mar 11, 2010 | 02:00 AM
im not too much of a fan expert per se but hows this look?
http://cgi.ebay.com/ebaymotors/PROCO...item439dc73fa1
the price is def in my budget and way less than troyer
Old Mar 11, 2010 | 08:56 AM
My controller was from autozone for a whopping 17.99 and its just a basic temp controller, but it has been very reliable
Old Mar 11, 2010 | 05:14 PM
motoman those are perfect, but see if you can find one with a lifetime warranty- one day one of my fans ground bolts came out so i thought it was the fan and the shipper sent me another no questions. while i was mounting it I found I had a ground wire just hanging.....so i have a new fan in my closet
Old Mar 13, 2010 | 10:39 AM
I found some further down the list on ebay with a lifetime warranty so I'll be ordering those next paycheck! I thnk I'm going to give the $17 autozone controller a shot before I go with the more expensive ones
Old Mar 13, 2010 | 04:43 PM
Perfect. Lifetime warranties rock when stuff goes wrong.
Correct me if I'm wrong, but Patrick is running his with a secondary switch. Mine handles two fans perfectly and you can adjust the on/off temp. His I believe is manual?
Old Mar 13, 2010 | 04:45 PM
i have one fan primary with temp control and both fans have their own manual on switches
Old Mar 15, 2010 | 01:49 AM
97XL's Avatar
Ordered mine on Friday, lifetime warranty...220W motor, 12A startup, 6-7A running. I plan on going with Pat's setup manual switches.
