Efan brackets
Yeah its pretty easy to do. Although the drill and hacksaw I used were at my parents house (I live in an apartment), its about $15 in hardware, really easy and fun to make.
If you need an exact length, just put a tape measure against your radiator since they sit flush with the top lip
BUMP
My old radiator finally died, so I upgraded to a dual-row radiator. Pics are from swapping over.
MMmmmm look at how big it is. You can never have too much cooling power!
Old radiator.
Always gotta compare
Fans mounted onto the new radiator. This process was 100x faster and easier than my first install since the radiator was OUT of the engine bay.
Old radiator.
Looks nice Alex ive had a dual core for a while now, definitely worth the upgrade, and the water temp gauge actually reads a hair cooler with the bigger radiator.
Hopefully you are using Ford Motorcraft Gold Coolant in there
Nah I've got the $9 special from O'Reillys. I took a test drive and with my 180* thermo, my trucks water temp is 175* and at red lights peaks 185*. Fans don't even come on (set to engage at 190*, off at 185*).
Problem is now my A/C isnt working
I thought it was lack of CFMs since my radiator is bigger, but draw is same as before using my paper method and even doing 75 mph down the interstate it keeps clicking on and off every 2 seconds.
