balljoints-question
Old Feb 19, 2010 | 10:44 PM
  #31
Tumba's Avatar
Check this guy out. I bought a complete set from a store like this on Ebay. They weren't brand name, but they were good quality parts, with grease zerks. I was really impressed by the parts when I received them.
http://shop.ebay.com/i.html?Model%25...=p3286.c0.m282
Old Feb 20, 2010 | 12:13 AM
  #32
mxRacer09's Avatar
Originally Posted by fordracing200
I need to do my balljoints, 00 4x4 f150, do I need to replace both control arm assemblies or no? I was told the upper is one piece but the lower presses out, then I was told they are both one piece???
mmmmk this is what you do go to auto zone get the 2 uppers and do em urself i just had to replace them myself just make sure u mark where the uppers sit for your alignment and the lowers hardly ever go out cuz most of your weight is on the uppers ya know! its easy it takes like 30 to 45 min to do it!
Old Feb 20, 2010 | 05:29 PM
  #33
fordracing200's Avatar
my right upper has 1.5" of play or better in it, its bad.....like sounds like the 149k mile shocks did....
Old Feb 20, 2010 | 05:31 PM
  #34
how hard do they come out with the press? real hard or no? I have an 1100ft lb impact gun, and a few big hammers....
Old Feb 20, 2010 | 06:17 PM
  #35
Tumba's Avatar
With the press, we just wrench them out. Not a big deal, you just have to get the right press sleeves in the right place. Impact would probably be OK, but they come out pretty good with the wrench. Make sure you have a big enough snap ring pliers. The set I had was a little small and wouldn't fully extend the snap ring off. I had to pop the snapring out of the groove and work it off with a screwdriver. Not really a big deal though.
Old Feb 21, 2010 | 01:24 AM
  #36
ive got the durlast ones and they suck big time the boots never fit on the ball joint correctly from the beginning. I wish i had spent more the firs t time, but i was in a pinch.....
Old Feb 21, 2010 | 07:37 AM
  #37
Tumba's Avatar
Again, I highly recomend the sets advertised on Ebay. You can buy everything but the pitman arm in the kits for $185 to $200, and the parts I received, look as good as any I've seen anywhere. If you don't need all of the parts, you still have spares for later.
The only problem I had, was the first press I rented from a parts store was bent by a previous user. So I took it back and went to another chain store and rented a different one. I have a younger guy that always helps me with these jobs, but we changed all of the parts in one afternoon, and even got the allignment within tollerences before taking it to the shop.
Old Feb 22, 2010 | 08:08 PM
  #38
Sweet....I am going to get it aligned after, I think I'm going to use napa ones. I'll probably just do the uppers then if the clunk doesn't go away do the lowers...
Old Feb 22, 2010 | 11:05 PM
  #39
illness95's Avatar
you highly reccomend the cheap chinese parts???
moog or go home with a broken truck
Old Feb 23, 2010 | 02:29 AM
  #40
Tumba's Avatar
I compaired them to moog, they are pretty good quality.
I hav had moog parts fail just as I have had FOMOCO parts fail
Edit: Here is a link to a list of where Moog ball joints are made.
http://www.federalmogul.com/en/SearchResults?q=ball%20joints
Old Feb 23, 2010 | 11:06 AM
  #41
GinosF150's Avatar
ford racing 2000, what sound did the shocks make?, at 157,000 i have a ratttle sound coming from both sides when i go over bumps, i don't know if it's the shocks or ball joints.
Thanks for any input.
Old Feb 23, 2010 | 11:40 PM
  #42
illness95's Avatar
http://www.federalmogul.com/en/Searc...=ball%20joints
well touche..
Old Feb 23, 2010 | 11:51 PM
  #43
a clunk like balljoints.....my old truck did the same thing, it had 211k miles on stock ford shocks.......they were WHIPPED!!!! These weren't too bad, the balljoints were most of the noise
Old Feb 23, 2010 | 11:57 PM
  #44
alex7191's Avatar
im pretty sure i know the exact sound you're talking about. i had that sound and when i replaced my shocks and coils the sound was still there. replaced my upper and lower balljoints and its gone now
Old Feb 24, 2010 | 06:50 AM
  #45
Tumba's Avatar
Your sound could be the end links on the torsion bar also. The rubber gommets go bad and they will rattle all the time.
