Adding leaf springs...
Old Jan 17, 2010 | 07:53 PM
tja349's Avatar
i was thinking of adding another leaf spring in order to support more weight and also lift it up a little.. is there anything i can do to the front to keep it level. also are spacers for the leaf springs bad? looking for a cheap way to lift and haul more.. any help appreciated
Old Jan 17, 2010 | 09:35 PM
4x4wolf's Avatar
Turn up the torsion bars will help with leveling the truck out
Old Jan 17, 2010 | 09:38 PM
n2muddavid101's Avatar
like he said crank up those torshon bars. it will help alot but dont crank them up all the way.
Old Jan 17, 2010 | 10:23 PM
fordracing200's Avatar
my buddy added 2 leafs out of a 7700 and it lifted his truck 4"...cranked the t bars and it looked great
Old Jan 17, 2010 | 10:29 PM
thejake1989's Avatar
ive been wanting to do that one for my rear. still looking for a set of springs.
Old Jan 18, 2010 | 12:01 AM
tja349's Avatar
would tightening the t bars compromise the cv and ball joints? do i need keys for the tbars?
Old Jan 18, 2010 | 12:03 AM
u can just use an adjustable wrinch so i of herd.
Old Jan 18, 2010 | 04:46 PM
it won't compromise ball joints, it wears more on the cv joints and pitman/idler arms, but nothing serious or immiediate. Its more of a problem on the GM trucks..
Old Jan 18, 2010 | 04:48 PM
I can get a set for 20 bucks at my local yard if I pull them....just 2wd springs but it doesn't matter, all I need is two of them....Put them under the 3rd spring down, got to get the 60 dollar set of u bolts though..bahh. I'll do it in the spring probably, the woodstove I've got is too small to keep the 3 car garage very warm....
Old Jan 18, 2010 | 09:33 PM
4x4wolf's Avatar
I've heard from a ford mechanic that the 97-98's if turned too much they used to break so don't max them out
Old Jan 21, 2010 | 02:40 PM
tja349's Avatar
the leafs are just stacked right? so if i go to a junkyard and pull one i can just slide it in correct? how do i know how much to crank the t bars
Old Jan 21, 2010 | 03:01 PM
why do you need longer u bolts? how many are you adding per side?
Old Jan 21, 2010 | 06:19 PM
2.....my friend added 2 and he had to get longer u bolts, U bolts stretch also, and aren't supposed to be re-used...not that anyone goes by that, just stating...but if you really don't need new ones for adding two then I won't bother, I think though that the stockers are too short. what snapped on the 97-98 trucks? The t bars or pitman/idler arms? I've never heard of or seen a t bar break, ford or gm, ever.
Old Jan 25, 2010 | 11:05 PM
nhford's Avatar
Supporting more weight... Would adding TIMBRENS be a possibility?
I replaced the stock 'bumpers' (sit on the rear axles) with a set TIMBRENS for maybe $50 bucks?
When I replaced my tires, I stepped up to an LT tire 'C' load rated.
Worked great in the rear, no more sag when I picked up a yard of loom, or stone.
Maybe Timbrens can be used in the front, too?
Old Jan 25, 2010 | 11:32 PM
thesnowman269's Avatar
Yes they can be used on the front as well as the rear. People with plows swear by timbrens up front most of the time.
