One wheel wonder!!!
Old Nov 22, 2009 | 08:25 PM
Ice-Cable's Avatar
One wheel wonder!!!
One wheel wonder, single wheel peel, single stripe hype, one tire frier, all of these derogatory, slanderous, albeit rhyming, phrases describe my truck. Does my 2001 SCrew not have a LS rear end? Am I to drive this beast with what I consider to be a sub par rear end? Or could it be that i am just not trying hard enough to get both wheels to turn? Help me figure this out....cause I need a posi!!!
Old Nov 22, 2009 | 08:28 PM
what does your axle code on your door jam sticker say?
Old Nov 22, 2009 | 08:35 PM
Raptor05121's Avatar
it does not have a LSD
Old Nov 22, 2009 | 08:46 PM
4.2trimble's Avatar
from the sounds of it you have an open diff. BUT the limited slips in these trucks go out then the diff will act like its open, untill it breaks.
axle code inside the door
Old Nov 22, 2009 | 08:47 PM
Ice-Cable's Avatar
Well isnt that just skippy.......i do appreciate the quick confirmation that my trucks **** end is mediocre, at best. Now I am going to have to get a LSD put in it.....anyone know a ballpark on cost for one???? or better yet, anyone got one they dont want?
Old Nov 22, 2009 | 08:49 PM
4.2trimble's Avatar
not sure on cost but id look into tru-trac limited slips.
have you regeared for the larger tires. this would be a good time to do it
Old Nov 22, 2009 | 09:01 PM
Ice-Cable's Avatar
Regear, sounds like something I may want to do....any suggestions on what regear i may want to use?
Old Nov 22, 2009 | 09:03 PM
4.2trimble's Avatar
do you plan on going any bigger in tire size? If not then 4.56's if you plan on going up to 37-38's then 4.88's
how often do you tow?
Old Nov 22, 2009 | 10:36 PM
RAM AIR's Avatar
If he has an 8.8 rear, then the biggest he can go will be 4.56's. He'll have to upgrade to a 9.75 to fit the 4.88's.
Old Nov 22, 2009 | 10:43 PM
b2therad's Avatar
Also with 4:56s he will have to get a notched cross pin
Old Nov 22, 2009 | 11:40 PM
Ice-Cable's Avatar
Alright now we are talking, lets go bigger.......seriously though, I have 325/65/18's, i tow in frequently and I have whatever rear end comes stock on an 01......so let me know what I need and I will get it done.
Old Nov 22, 2009 | 11:44 PM
Paralyzer's Avatar
just curious...i had 4.88s in my ranger with an 8.8 rear whats the limiting factor on the f150?
Old Nov 22, 2009 | 11:56 PM
b2therad's Avatar
It has something to do with the diff. cover I think. I had never heard that you couldnt go bigger than 4:56 on a 8.8, but I would also assume that RAM AIR knows what he is talking about as he has re-geared his truck already. I was told that I will need to get a aftermarket diff. cover when I re-gear my 8.8 which is really soon... hopefully.
Old Nov 23, 2009 | 12:04 AM
Paralyzer's Avatar
strange...even my ranger was able to reuse the factory cover didnt even need a notched pin..
Old Nov 23, 2009 | 12:05 AM
b2therad's Avatar
Your ranger was a beast!
