03 front lift????
03 front lift????
I currently have after market torsion keys on my 03 f150 and they are wearing out the front end of my truck. I would go back to my stock keys but i wouldn't be able to fit my tires that are currently on the truck. so what i would like to do is get the parts for a 3 or 4in suspension lift for just the front to keep the level look. does anyone know where i can buy just the front parts or have any advice that could keep my truck level without wearing out the front end??
you can get a 3" bl with your cranked t-bars and to the op the aftermarket keys are the reason its wearing out since they allow you to put too much load on the suspension.
id put the stock keys and a 3" bl
yep. what he said. body lift is going to be your cheapest way to go. make sure you crank those aftermarket t bars all the way down. it will fix your front end problem and you will get a better ride as well.
agreed it does look like theres already a BL on there now
you can find go used 6" Fabtechs lifts for CHEAP.
i wouldnt put a different lift on my truck if it was still IFS FABTECH all the way
At least 1.5 turns, it made a big difference all around, but I have the long bars and factory keys.
