7k lbs payload
Not bad. I think the most I ever had was 3 yards of mulch in my F150. Weighed like 2-2.5k maybe. It isn't something I every want to do again but at the time it was the only option since I didn't have the F250 yet. When I do it again this summer I'll most likely use the F250 so the weight isn't as much of an issue. Gotta put new springs on it first. 17 years of plowing as taken it's toll on this poor old thing.
By the way, CC/LB SRW is my dream truck. I love your truck.
This is my dads truck. This is just one of the many adventures this truck had, most days this thing is running 12+ hours all over long island. It tows 30 foot boats, hauls dirt, sand and concrete, cast iron boilers and doubles as his supervisors truck when we do snow reoval at the airport. i tried to convince him to buy a 350, but he said "what do i need a 1 ton truck for?" Well this thing grins and bears it, so i guess hes right. Built Ford Tough Baby!!!
Yes, those are LT load range E tires. properly inflated. No add-a-leaf. just good old detroit steel. there was 8 inch thick peices of concrete in there. this was the third load of the day. My brother loaded it up and then realized the dump was closed. I had to put a jackstand under the hitch to releive some pressure.
And its a 4.6
And its a 4.6
It's amazing how proud people are of abusing their trucks!
Next thing you know people will be bosting how many years it has been since they changed their oil!
Just because they didn't break with a load in them doesn't mean they won't still break.
Metal fatigue is a crazy thing. Work hardening or cyrstalizing the metal to the point where it becomes brittle. Then, years or days later hit a pot hole and break a spindle, spring or axle. Then they curse the truck because when it was newer it worked great! I deal with this daily in trailers and work trucks.
Btw, adding leaves, replacing with heavier springs, airbags, etc., does not give you more capacity. The frame, axles, driveshat, tranny, engine, etc. is what determines capacity. All added springs do is raise the load (and also give a stiffer ride that causes more vibration and shock, which causes more stress...it's a vicious cycle).
