tire gearing
Old 02-11-2007, 12:53 PM
05extcabflare's Avatar
tire gearing
I was watching exteme4x4 the feb 11 episode, when changing tire size you divide new tire size by the old tire size then muliptly stock gearing, it will give you a new gear ratio u need to run.
example: 35" new tire, divide old 32" tire size, then muliply the stock gear ratio (mine is 3.73) = 4.07 Hope this makes sense
Old 02-12-2007, 09:34 AM
T-roy's Avatar
BFG has a tool that does a couple different calculations when changing tire sizes. Its on the right hand side of this link under "Tire Tips".
http://www.bfgoodrichtires.com/bfg/productIdSubmit.do
Old 02-12-2007, 07:42 PM
blank screen
I clicked on that link and it was blank screen
Old 02-12-2007, 08:02 PM
APT's Avatar
APT
APT is offline
Yes, that'll get you the effective gear ration. Remember that larger tires weigh more so you'd want an even shorter gear than that if spending the bucks to change them.
35" tires = 4.56 IMHO. 36-37" 4.88:1
Old 02-13-2007, 11:08 AM
Knarf0486's Avatar
I believe it is 4wheelparts.com that has a tire size / gear ratio chart. Give you several options depending on the style of driving you desire.
Old 02-13-2007, 01:19 PM
jiggle's Avatar
4LO.com has some really great calculators. They even have a Blood Alcohol Content calculator just in case you want to go mudding after a few brews.
Old 02-14-2007, 01:06 AM
T-roy's Avatar
sorry about that, this one should work. Still click on "tire tips".
http://www.bfgoodrichtires.com/bfgap...7&target=index
Old 02-14-2007, 09:40 PM
thanks it worked
Quick Reply: tire gearing
