Does 2001 5 lug fit on 98 5 lug?
Hello,
I wanted to comment on the statement that the wheel would center itself on the lugs. Is that true? As I remember, our trucks don't have tapered lug nuts. They're "hub-centric". All our lug nuts do is hold the wheel to the hub, not locate the wheel. From what I have understood, a 14mm lug wheel would be centered on the hub of a 12mm wheel truck, but there would be play between the wheel and the hub in the rotational direction and eventually the lug holes would become elongated/distorted. Someone on this discussion page once upon a time was trying to find and/or fabricate shims/spacers to fix this issue. I can't remember his name. Somebody chime in and let me know if I'm on the right track.
Fordman3
Fordman3
I took wheels off a 99 and put them on a 03 for someone and they fit but the thicker lugs were a tight fit. The only way to really tell is to try them. If the wheels were lug centric for the older truck they won't fit, but if they are hub centric they will work. Are you talking about factory wheels or after-market?
