p0300 code
Old 04-21-2011, 11:58 AM
mav015's Avatar
p0300 code
Ok so i have a 5.4 2006 xlt, i have 120k on the motor. I had new plugs put in(no plugs cracked), and i did the coils. After the work was done p0300 came up i put new coils in angain, cleaned the air filter(amsoil dry filter), and i replaced my fuel filter about 30,000 miles ago. Should i pull all the plugs and put new ones in.
Any ideas on how to fix this?
Thanks yall
Old 04-21-2011, 03:51 PM
jethat's Avatar
wait until you get the p030x code that identifies the cylinder. Do you have a noticeable miss? What plugs did you use? I'd get it to give the cylinder code if it were me before you throw any thing else at it..
Old 04-21-2011, 09:34 PM
CATBACK's Avatar
P0300 code indicates random misfires and I've only seen it with more than 1 cyclinder. A single Cylinder should throw a single P030x without a P0300.
Jethat is right..wait to see what hatches.
JETHAT--like that MACH1 there. I have a 71 in my garage listing but not stock looking..
Old 04-21-2011, 10:48 PM
jbrew's Avatar
Yep, -PO300 "Random Misfire" just informs the tech to mode 6 it, - the info is recorded in cylinder history. Does us absolutely no good, we don't have that $10,000 diagnostic equipment to read it's mind...
I'd push the engine until the CEL blinks 5 or 6 times. Once that happens, do this one more time, - maybe the scanner will give you better direction once that's been achieved. It's worked in the past.
Otherwise, it's off to the dealership.
Old 04-23-2011, 01:42 AM
mav015's Avatar
ok so i worked the hell out of the truck still just p0300. At idle you can tell that its missin, i used the champions.
Well i dont know think i might have to end up bringing the truck to a shop
thanks yall
Old 04-23-2011, 01:51 AM
glc is offline
You may want to pull the Champions out and put Motorcrafts back in. Not everyone is having good luck with the Champions.
Old 04-23-2011, 12:07 PM
jethat's Avatar
X2.. I wouldnt use Champion plugs myself in my lawnmower.. I would still get it to give up the code. It will eventually. Try going up a hill slowly that might do it put a load on the engine..
Old 04-23-2011, 04:16 PM
mav015's Avatar
thanks guy ill get the champions out, and pulled 28 foot boat with it yesterday and it still just said p0300
thanks yall
Old 04-23-2011, 04:44 PM
jbrew's Avatar
Yes, remove those Champions lol.
Run ONLY - Motorcraft, Denso's or NGK's for that engine. NOT Autolites!
Old 04-24-2011, 12:37 PM
glc is offline
No Denso or NGK for the 3v.
Old 04-24-2011, 03:23 PM
jbrew's Avatar
Crap! That's right, - I'm mistaken, that's for a 2 valve not the 3 valve. Thought the OP had a pre 04 model 2 valve for some reason.
The Champions can cause headaches in the 3V as well. There you better off with the Motorcrafts IMO.
Old 04-25-2011, 08:58 AM
mav015's Avatar
thanks guys im goin to get them out this weekend
Quick Reply: p0300 code
