Cil #2 Misfire
Old 06-11-2010, 09:23 PM
wutagoalie's Avatar
Cil #2 Misfire
99 4.6L 2WD
My truck stumbles and hesitates badly. I scanned a code P0302, Cillinder #2 misfire. No other codes came up.
What would be the most common problem for this, plug or wire?
How do i test a wire?
Also, what years had the problems of breaking plugs on removal?
Old 06-12-2010, 12:37 AM
Toyz's Avatar
04-08 were the breakage issues, 3v motors. Ours had the "spit out" issues. But can easily be avoided with proper installation.
How many miles on the plugs/wires?
If you have some miles on the thing, do your truck a favor and give it some new plugs and wires. Otherwise, you can test the wire firing signal with a light, or put a good plug in it and check it. You already know which cylinder it is, if the pockets are tight, pick up a new plug for a few bucks and set of wires.
Old 06-12-2010, 04:43 PM
wutagoalie's Avatar
does anyone have a link on here of a good thread with changing plugs, with pictures?
Old 06-12-2010, 05:43 PM
jbrew's Avatar
This one covers the basics. Except, don't use anti-seize and you have plug wires instead of dedicated coils.
You can use it for the basics tho -
http://rmftc.com/howtos/sparkplugs/sparkplugs.html
Old 06-12-2010, 05:47 PM
jbrew's Avatar
Plug wires:
Check the plug wire resistance using an ohmmeter. Touch the metal connectors inside the wire boots with the meter leads to get a resistance value.
You should read at least 12,000 ohms per foot of plug wire but no more than 50,000 ohms total for a long wire; otherwise its resistance is worn down and you should replace it.
Good Luck
Old 06-13-2010, 10:22 AM
wutagoalie's Avatar
Thanks Jbrew. Is the removal of the fuel line and power steering res the same on my 4.6?
Also 5/8 is the size for my plug socket as well?
Old 06-13-2010, 11:20 AM
jbrew's Avatar
Yes, Yes and Yes Man.
Old 06-13-2010, 04:24 PM
wutagoalie's Avatar
do i have a separate coil pack where 4 plug wires plug into on each side?
Also what is the fire order for my 4.6?
Old 06-13-2010, 04:34 PM
jbrew's Avatar
What ????? Concerned
Here's how she's set up ~
So firing order would be = 13726548
Old 06-13-2010, 05:23 PM
wutagoalie's Avatar
The 2 small squares at the bottom of the chart that you posted, is that the coils?
Old 06-13-2010, 05:46 PM
YES, those would be the Coil Packs
Old 06-16-2010, 10:35 PM
wutagoalie's Avatar
If i go ahead and change my plugs and wires. Is it ok to leave the coil packs? I dont want to change them if they are fine
Old 06-17-2010, 10:05 AM
glc is offline
You can swap the 2 coil packs and see if the miss changes cylinders.
Highly recommended - Motorcraft plugs and wires, no aftermarket brands.
Old 06-19-2010, 07:39 PM
wutagoalie's Avatar
I took a look under the hood, since i saw on the diagram what plug was #2, and sure enough the plug boot on the #2 plug was not seated correctly, it was slightly raised, so i snapped it back in and have not had a problem all week, its been running great.
Im going to go ahead and change out my plugs and wires, i noticed that i have a/c delco wires on there now that were done a few years back.
I will replace plugs and wires with motocraft.
So i should be ok with my coil packs, since my misfire issue is gone?
Quick Reply: Cil #2 Misfire
