serpentine belt replacement
Gates -
http://info.rockauto.com/Gates/Detai...leetRunner.jpg
Gates suggests replacing the tensioner at the the same time - Good Idea.
http://www.gates.com/file_display_co...3%2D0796%2Epdf
To remove - 1/2 breaker bar/release tension @ tensioner/Insert breaker bar end into square inlet on tensioner ("B").
Three 10mm blots remove tensioner if replacing. Very easy.
Belt routing is stickered under the hood. Sticker missing? Here -
I like the Goodyear Gator-back belt. But that Gates belt looks good too.
http://store.summitracing.com/egnsea...4&autoview=sku
Phil
Phil
Thanks! A fast one too - took about 3 minutes, if that .
BTW- Count the ribs on your existing belt, there's 6 and 8 rib. Not sure which one others may have, I think most are 8.? Normally two sizes apply w/AC or w/out AC.
I was referring to the write up. Yea, the belt doesn't take that long either. On the 97-03's anyway. I haven't had the pleasure with a 04 plus, fun ehh.
