Wireing question
Wireing question
Hey gang. New to this board. I have read a lot of post here. and have a question. I recently changed my timing chain assy. on my '01 4.6 F150 S. Crew. Found out the motor was an '00. I usually don't have issues with putting things back together but this time it took me a little longer to complete the job. I was only able to work on it about an hour a day. Long story short. I have it back together but I have a wire that I can't figgure out where it goes. It is on the drivers side bottom. 1 wire goes to the oil filter but dont know where the other one next to it goes. OOPS!!!!! Thanks in advance for your help.
Hey gang. New to this board. I have read a lot of post here. and have a question. I recently changed my timing chain assy. on my '01 F150 S. Crew. Found out the motor was an '00. I usually don't have issues with putting things back together but this time it took me a little longer to complete the job. I was only able to work on it about an hour a day. Long story short. I have it back together but I have a wire that I can't figgure out where it goes. It is on the drivers side bottom. 1 wire goes to the oil filter but dont know where the other one next to it goes. OOPS!!!!! Thanks in advance for your help.
Engine size?
Sorry. The plug itself is black. The inside is red. I have the cam sensor pluged. Crank sensor makes sense. The only problem is I can not for the life of me find where it plugs into. I had the whole front apart and even the LF tire off and I see no where to plug this into. Can you direct? Thanks
Here is a diagram.
Don't worry about it - it's an extra in the harness - 5fours have one there as well . It's an EVO steering connector(Electronic assist) - You don't have it. The only wire /bottom of the drivers side that you need to worry about is the oil sending unit connect - that's it.
Does it look like this -
That's a good filter tho - It's a WIX. - One of the very best, if not the best.
There designed very similar to the Purolator. - and Motorcraft is a Purolator hybrid anyway.
