have a spark issue also says lean
Hi my 97 f150 4.6 has a missfire on the computer when I had the check engine light scanned.It alsosaid fuel system lean on bank 1and 2.The truck hasn't skipped fire that I could feel but it has lost power and got harder on fuel. The mechanic took out a couple plugs and said they looked black and to try a set of plugs and wires the coils were already replaced,does anyone else have any suggestions it is greatly appreciated.THANKS
OORRRR- The wrong dang plugs are in there, if not, could be a fuel problem - maybe both...What spark plugs are you running ? When was the filter changed last?
Take a good look at all your PCV system lines - They develop holes in the rubber parts and the hard-line can fracture. Replace the PCV valve lately ?
Clean the MAF Sensor, if it hasn't been done in awhile.
Some helpful links -
http://www.fordf150.net/howto/clean-...low-sensor.php
http://www.fordf150.net/howto/fuelfilter.php
http://www.fordf150.net/howto/throttlebodyclean.php
Good Luck
Good Luck
Did you fix the misfire ? That's the first area that should be addressed? Lean codes will only cause a misfire situation if your fuel pump and regulator are not working properly. You may want to pressure test the pump + test the reg.
Anyway , your PCV system looks similar to this -
Ok so I am going to check the fuel pressure soon and was just wondering if the place that you hook up the guage is from what i found on the search on the fuel lines on the pass side and the pressure should be about 35psi.Just wondering if I had this right and also is there a certain kind of fuel psi guage for this cause I will need to buy one. Thanks
Just make sure it has a Ford Adapter if you purchase one. It will say on the packaging.
If you choose to use your old gauge and don't have a Ford adapter - using a valve stem tool, remove stem @ schrader valve and attach your gauge hose to the rail schrader w/hose clamp.
@ idle 30-45 psi
@ idle w/vacuum hose detached 40-50 psi
Hold pressure/key off/after 5 minutes 30-40 psi
System MAX = 65 psi
_______________________________________________
Regulator -
Connect a hand held vacuum pump to the regulator and read fuel pressure w/vacuum applied. Pressure should decease as vacuum is increased. (Vac pump tool is available @ most auto supply stores $20-$30.)
Detach the vacuum line from the regulator and verify vacuum is present when the engine is running.
