studder at acceleration
Old Feb 28, 2008 | 05:00 PM
TCWinters's Avatar
When i let of the clutch and start giving it gas it studders really bad. Once i hit about 1500 rmps it goes away. It will cruise just fine and run at high rpms just fine. I have changed all spark plugs and checked coil packs. Could this be caused by a clogged fuel injector? Any other ideas?
Old Feb 28, 2008 | 06:18 PM
jbrew's Avatar
I suggest you post the motor you have in the truck. What plugs did you use and what did you pull out of there.
Sounds like the EGR valve is hanging or a low grade mis. Yes it could be the fuel filter or regulator. Go thru the common cleaning procedures along with general maintenance listed in the manual.
Use the search this forum option (top right) in the engines section for good info.
Old Feb 28, 2008 | 06:21 PM
TCWinters's Avatar
sorry...its a 4.6, i used autolite platinum spark plugs, i've recently changed the fuel filter, and changed the egr valve last year to pass emissions
Old Feb 28, 2008 | 06:42 PM
TCWinters's Avatar
oh yeah...my cel is on but the code says i have an evap system leak. Could this effect anything?
Old Feb 28, 2008 | 06:51 PM
It sure can - you need to fix the causes of CEL codes before you can address drivability issues.
Old Feb 28, 2008 | 06:53 PM
jbrew's Avatar
What plugs did you pull out? What was in it?
Old Feb 28, 2008 | 08:42 PM
TCWinters's Avatar
Same thing. Autolite platinum
Old Feb 29, 2008 | 12:51 AM
jbrew's Avatar
Yea , you need to run the right plugs before suspecting another area for problems. Autolites aren't a spec plug for your motor and many have run into the same problem that you have.
I would put the correct plugs that are spec'ed by Ford. These engines are picky when it comes to plugs.
Use the search bar , there was just someone last week with the same problem you have and he couldn't believe the difference in the way it ran with the OEM spec plugs in it.
You want to run the Motorcraft plugs and stay away from Autolite, Bosch plugs.
Old Feb 29, 2008 | 12:56 AM
joshmac4.6's Avatar
Which code did it have, large leak or small leak? A large leak can be something simple like a loose gas cap. But ditto from jbrew, use the factory plugs, they will run and perform so much better.
Old Feb 29, 2008 | 01:32 AM
jbrew's Avatar
Opps , I missed that :o
I didn't see the EVAP leak post.. Well, heres an illustration of the system in case your trying to troubleshoot -
Old Feb 29, 2008 | 09:29 PM
TCWinters's Avatar
thanks for the diagram...i believe it is a small leak
