Truck Missing Dealer may be wrong?
Hello forum I have a 2006 F-150 with 70,000 miles on it. The only modification that has been done to the motor is a K & n Cold air kit. Well my truk the last month when I went to pass under full pedal will miss and the check engine light will flash then a mile down the road everything will return to normal now just wout of the clear blue it will ose all power and miss. Now it is running better and mycheck engine light is staying on constantly, I took it to the dealer and they blamed my cold air intake and said it was ruining my mass air flow sensor ause there was some "dust" on the sensor are they for real or are they shooting in the dark like they do most of the time
Thanks for your help
If you look around (SEARCH) the chips forum, you'll see that a CAI can cause a lean condition.....which can activate the CEL. Your dealer may not be wrong.
https://www.f150online.com/forums/sh...18&postcount=5
If you clean the MAF, you can use brake cleaner....spray the little wires inside and then use compressed air to dry it (like the kind in a can typically used for computers). Reset the PCM by disconnecting the battery for 15-ish minutes. If you get another CEL, it could be the CAI. Maybe think about a tuner....
Originally Posted by 02XLT4X4
The only way to move more air is with bigger holes, bigger holes let more stuff in.
The other way to move more air is with MORE holes, not just larger holes. The K&Ns often have more surface area and more holes than their equivalent woven paper counterpart. That doesn't make them any more efficient.
....but they do let more stuff by.
Originally Posted by glc
Oil from the K&N getting onto the MAF sensor wires is a known issue. Clean your MAF.
Going to clean the MAF in my Expy this weekend. It's spitting out the PO174 and PO172 codes.
