Dielectric Grease
Pull the boot from the coil, the spring should stay attached to the coil - if not tighten the winding and reattach on the coil blade. Make sure the springs are fully pushed on the coil blade .
Dielectric Grease - cover a long screw driver blade with the grease and insert it into an empty boot. Coat the entire insides of the boot well - don't worry if you get some on the spring when you put it back together. Then grease around the top seam of the boot where it meets the COP. After install grease the void between the cylinder head and boot to keep moister from building inside the plug chamber..
Thanks, Actually , most everything I do is learned from others on this site. It does help that I've owned Fords all my life, still , I gained more knowledge from this site than I had before hand.
Documenting threw pictures and and diagrams can't be beat!!
"This sites better than any book, CD or DVD that's available to the average Joe"
