5.4 Piston Slap? May be time for a change
Well up in Tahoe this weekend I think the engine developed a noise to what sounds to me like piston slap. Not good either way.
Question is, what is my best option? I have a 98 Navigator 4x4 with the 2v 5.4. I have no issue with rebuilding the motor, or possibly just slapping in a replacement. But what about upgrading to DOHC? What all is involved? Will I need to change out the computer and engine harness if I go that route? And I'm not positive, but doesn't the newer 2v motors have more hp? like 99 and up?
Any guidance is greatly appreciated.
Thanks!
Thanks!
Y
Don't worry about it. Mine (97 5.4L) got the Slap at about 30K. It now has 218K on the engine. Still has the Slap, but once it warms up, the engine runs absolutely beautiful. A friend of mine had a 97 Expedition with the 5.4L in it. He had the Slap as well. His had 323K on it when he traded it in. Still ran fine. I'm really inclined to believe these motors last longer WITH the Slap.....
Y
If it does it all the time, it is not piston slap....Might be a bad rod. Piston Slap only happens when the engine (usually only with aluminum skirted pistons) is cold. There is extra room for the piston skirt to rock back and forth until the piston begins to heat up. When it heats, the skirt expands to fill the cylinder, and the piston no longer rocks back and forth, and you get no more rattling. If the piston is too tight when cold, it expands, and if tight enough, internal parts break.
Let me clarify a little. The slapping, or knocking I hear is only under a light load.... like going down a flat road with the throttle on real light. Under heavy acceleration or idle it isn't apparent. It's not a deep knock so I don't think it's a bearing issue, plus oil pressure is still good. Almost sounds like it could be valve train noise. It's similar to the noise you hear on a cold start, which is apparently piston slap on these things. It does burn a little oil so maybe the rings are just shot.
Does anybody have any info on the DOHC swap? I've considered doing this before but I don't know what it would consist of. At least for future reference if anything.
I'm positive it's not an exhaust leak.
It may just be more apparent because it's been 20 degrees outside, I dunno. Guess I'll find out, I don't plan on doing much until the motor just gives up.
So nobody has any info on changing to a DOHC motor? Or if the 99 and up SOHC motors have more hp than the 98's? I searched around and didn't find much......
