White Foam on oil filler cap.
A couple days ago I took my 1999 F150 5.4 V8 (140k) out for a good snow bog. The next morning when I went to add oil I noticed a white, milky substance on the bottom of the oil filler cap. I changed the oil that same day. A couple days later, after some more snow bogging, the white substance has returned. I did not notice this when adding oil in previous weeks. It has been much colder as of late and I did work the truck pretty hard in 4-wheel drive. Please tell me something's not leaking into the engine. The coolant level seems to be normal.
Matt
Matt
Yeah this comes from oil not getting hot enough to burn off the condensation as others have stated. Running the truck for longer periods of time usually helps this, but it seems to be due to the cold weather more than anything. I used to have a dodge that would do that even in the lame winters we have in tx. After swapping to synth oil didnt seem to notice it near as much.
the detergents in the oil cause the oil and water to emusify, that is what the white stuff is!
moving to AZ usually solves the problem. of course when I fell in a 3 foot hole in a muddy stream on my dirt bike, i had the white residue on the dip stick. drained the oil and let the plug out for a week and still had the white stuff after changing oil. so i started the bike and let it idle without the dipstick. that got rid of it.
It's just condensation
It is just condensation I have had the same issue with my 05 Scab in the winter. If it was a blown head gasket you would see oil in your coolant and the coolant level would low along with the milky residue on your dip-stick and oil-fill cap. But it never hurts to ask your local service shop for their eyeball on the situation, they may see something that you're not.
